problems with I2C.... and ideas why dosent work?
Results 1 to 26 of 26
    Feb 2004
    Germany
    Snood,
    this is a perfect time to have a look at the datasheet and the examples you have got.
    If you are expecting any further assistance post your schematic and code.
    (please cut the code down to the minimum required for reading writing the RTC / EEPROM)
    But before posting please do some reading!
    regards
    Ralph
    snood's Avatar
    snood Guest
    please..... i have read the data sheet over and over again, ive read various places about I2C and i have studied the sample codes that i have been pointed to and still not a clue
    TRISB = %11111111
    second VAR BYTE
    minute VAR BYTE
    hour VAR BYTE
    day VAR BYTE
    date VAR BYTE
    month VAR BYTE
    year VAR BYTE
    ITCDEVICE VAR BYTE
    ITCADDRESS VAR WORD
    SDA VAR PORTC.4
    SCL VAR PORTC.3
    ITCDEVICE = $D0
    ITCADDRESS = $00
    second = 0
    minute = 0
    hour = 12
    day = 2
    date = 25
    year = 5
    I2CWrite SDA, SCL, ITCDEVICE, ITCADDRESS, [second, minute, hour, day, date, month, year]
    Pause 500
    I2CRead SDA, SCL, ITCDEVICE, ITCADDRESS, [second, minute, hour, day, date, month, year]
    at this point i dend the variables to my LCD and what comes up on the screen is "16"
    thanks
    Snood
    edit: it's been suggested to me that as i'm recieving "16" or a single "f" that maybe something is holding the data line up? still clueless other than that
    Feb 2004
    Germany
    ITCADDRESS VAR WORD
    the RTC requires a BYTE address, not WORD !
    second = 0
    minute = 0
    hour = 12
    day = 2
    date = 25
    year = 5
    1. there is no explicit value in "month"
    2. the RTC uses BCD format, the decimal values you are writing to the RTC don't make much sense.
    Now it's up to you to find out what the correct format would look like.
    without a schematic we can't help
    You have already got more information than you would ever need to solve this problem.
    Do some work on your own.
    regards
    Ralph
    snood's Avatar
    snood Guest
    the pic will automaticaly transmit the numbers in BCD.... even mel uses just regular numbers... and the missing month value is just a typing error, it is infact in my program.
    a direct quote from the DS1307 datasheet:
    "After the DS1307 acknowledges the slave address + write bit, the master transmits a word address to the DS1307."
    WORD address
    as fror the schematic... it's connected in the same fassion as the typical operating citcuit in the datasheet with 4k7 pullups... the Square wawe pin is just left hanging as i'm not using it.
    please stop telling me to do my own work... the questions i ask are simply what i cant find myself so i'm calling upon the expertese of other people. if you dont know how to solve my problem then just say so.
    Snood
    Feb 2004
    Germany
    This DOES work:
    I2CWrite SDA, SCL, $D0,0, [second, minute, hour, day, date, month, year]
    Pause 500
    I2CRead SDA, SCL, $D0, 0, [second, minute, hour, day, date, month, year]
    what more do you want?
    we can't fix your hardware remotely.
    WOW, that's great, so I can save a lot of codespace by removing all those conversions from my programs and let the PIC do it on it's own.
    But how do you tell the PIC what format you want/need?
    (or is there some kind of "Do What I Mean" Wizzard I didn't know about yet?)
    OK, there will be silence on this thread now...
    regards
    Ralph
    New England
    Hi snood,
    Odd... You've got this:
    I can't find that quote at all in my 1307 data sheet. Mine says this:
    "The DS1307 operates as a slave device on the serial bus. Access is obtained by implementing a START condition and providing a device identification code followed by a register address."
    "device identification code" and "register address" are both bytes.
    My code works fine with bytes for both items.
    Are you certain you're reading a 1307 data sheet - sounds more like the sheet for the 1340?
    Arch
    snood's Avatar
    snood Guest
    i got the datasheet here: http://pdfserv.maxim-ic.com/en/ds/DS1307.pdf
    under the "Slave Receiver Mode (Write Mode)" section of page 11
    also on page 12 the data diagram shws a word address.
    this is highly confusing.
    Snood
    edit: equaly it says: The DS1307 operates as a slave device on the I2C bus. Access is obtained by implementing a START
    not "serial" but "i2c"
    are you looking at an old version maybe?
  1. I2C problems
    By Mad_Labs in forum mel PIC BASIC Pro
    Last Post: - 25th September 2005, 05:22
