A new challenge (I'm in trouble again)
Results 1 to 6 of 6
    Default Re: A new challenge (I'm in trouble again)
    Was about end 2007 to 2008 ...
    not sure it has been lost ...
    Wow !!! got it in my archives ( 04/2008 )
    '@ device pic12f675,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off, bod_on
    @    __config _INTRC_OSC_NOCLKOUT & _PWRTE_ON & _WDT_OFF &_BODEN_ON & _MCLRE_OFF & _CP_OFF
    'Config
    'OSCCON  = %01100110
    CMCON  = %00000111     ' Disable comparator
    VRCON   = %00000000     ' disable
    ADCON0  = %11100000
    ANSEL   = %10000000
    '       I/Os
    GPIO    = %00000000   ' All outputs low
    TRISIO  = %00000000      ' no inputs
    'Aliases
    BODbit   var GPIO.0
    PORbit   var GPIO.1
    BOD   var GPIO.2
    LED   var GPIO.4
    ' Init vars
    Selection var Byte
    Ton   var Word
    Toff  var Word
    Coldstart:
    IF PCON.1 = 0 and PCON.0 = 0 THEN BODbit = 1 'BROWN OUT RESET BIT
    IF PCON.1 = 0      THEN
      PORbit = 1         'POWER ON RESET BIT
                 ' For debugging purpose only !!!
      Selection = 1        'Lights LED @ 25%
    PAUSE 1000
    GPIO = 0
    IF PCON.1 = 1 AND PCON.0 = 0 THEN    'PCON.0 = BOD ;PCON.1 = POR
        BOD  = 1              'GPIO.1 red led PIN6 shows a BOD state
        PAUSE 1000        ' For debugging purpose only !!!
        GPIO  = 0
        Selection =  ( Selection + 1 )// 5
    PCON.1 = 1
    PCON.0 = 1
    'Program choice
    SELECT CASE Selection
     CASE 0
       Ton = 0   ' Stop
     CASE 1
      Ton = 500  ' 25%
     CASE 2
      Ton = 700  ' 50%
     CASE 3
      Ton = 870  ' 75%
     CASE 4
      Ton = 1000  '100%
    END SELECT
    'Power Drive
    Toff  = 2000 - Ton
    IF Ton = 0  THEN       ' LED OFF
     LED = 0
     @ SLEEP       ' IF Power = 0 then snore !!!
     @ NOP        ' and wait for a Power off ...
             ' That ALSO saves the batt ...
    'NOTE : WAKE UP is achieved by Powering OFF the device ... not the classical way !
    '  !!! WDT MUST be OFF !!!
    IF Ton = 1000  THEN      ' LED @ 100%
     LED = 1
     WHILE 1       ' Endless loop until power Off !!!
        WEND
    WHILE 1        ' Soft PWM @ 500Hz until power OFF
     LED  = 1
     PAUSEUS Ton
     LED  = 0
     PAUSEUS Toff
    WEND
    have fun ...
