ASCII HEX Word to Decimal conversion....
Results 1 to 8 of 8
    Jul 2011
    Hawaii
    Default Re: ASCII HEX Word to Decimal conversion....
    John,
    You need to convert from ASCII to binary value. 4 bytes become 2 bytes.
    Add the following:
    ' New variables
    x var byte
    y var byte
    i var byte
    ' ************* ASCII to Binary **************
    for i = 0 to 2 step 2
    if PRITIM[i] > $40 THEN ' Handle MSNibble.
    x = PRITIM[i] + 1
    x.3 = 1
    x = x << 4
    x = PRITIM[i]
    x = PRITIM[i] << 4
    if pritim[i + 1] > $40 then ' Handle LSNibble.
    y = PRITIM[i + 1] + 1
    y.3 =1
    y = y & %00001111
    y = PRITIM[i + 1]
    y = y & %00001111
    if i = 0 then
    YEAR.byte1 = x | y
    YEAR.BYTE0 = x | y
    next i
    '************* END of ASCII to Binary *************
    YEAR is now ready to be sent to LCD display.
    - Martin
    These displays are ASCII. So no need to convert. Try the line below it will send ASCII $32,$30,$31,32 =(2,0,1,2)to the lcd. You may have to reverse the order PRITIM[X]'s ? Depending on the order you receive the data.
    LCDOUT $FE, $80, "YEAR =",PRITIM[3],PRITIM[2],PRITIN[1],PRITIM[0]
