16F88 and MPLAB fuse setting problem
Results 1 to 2 of 2
    Default 16F88 and MPLAB fuse setting problem
    Hi
    I try to use a 16F88 with mplab as compiler, i want to use mclr as I/O and the internal oscilator
    but i'm getting an error:
    error 118 ..... overwriting previous address contents (2007)
    ; Set fuses:;=========================================== ===============================================@ __config _CONFIG1, _INTRC_IO & _WDT_OFF & _PWRTE_OFF & _MCLR_ON & _LVP_OFF & _CP_OFF@ __config _CONFIG2, _FCMEN_OFF & _IESO_OFF
    Default Re: 16F88 and MPLAB fuse setting problem
    If this is with a version prior to PBP3 you must, if you want to have the CONFIG in your code, comment them out in the .inc file located in your PBP folder.
    An laternative options is to edit the default CONFIG in the .inc file instead of commenting it out and putting it in your code.
    For the 16F88.inc it looks like this
            NOLIST
        ifdef PM_USED
            LIST
            include 'M16F88.INC' ; PM header
            device  pic16F88, hs_osc, wdt_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F88, r = dec, w = -302
            INCLUDE "P16F88.INC" ; MPASM  Header
            __config _CONFIG1, _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
            NOLIST
            LIST
    So either put the CONFIGs you want in there, or comment that line out and put them in your code.
    If you're using PBP3 then open the manual and have a look at #CONFIG / #ENDCONFIG
