send 9 bits via hserout
Results 1 to 2 of 2
    Feb 2008
    Default send 9 bits via hserout
    Hello Folks,
    I'd like to build my own serial communication protocol with rs485. Therefore I have to send the data in 9 bit mode.
    Example:
    first byte + 9th bit set -> that's the adress of the slave
    all other bytes are send without the 9th bit set to indicate they're no adress bytes.
    Question: How can I set the 9th bit manually?
    my code so far:
    DEFINE HSER_BAUD 19200        'Set Baud rate to 19200bps
    DEFINE HSER_BITS 8        'Set to 8 bit mode
    DEFINE HSER_EVEN 1        'Set Even Parity
    DEFINE HSER_CLROERR 1         'Clear overflow error automatically
    ... some other code ...
    HSEROUT [Slaveadress,Datalength,Databyte,Databyte ...until datalength reached...]
    I will change the line:
    into:
    DEFINE HSER_BITS 9        'Set to 9 bit mode
    But how can I set the 9th bit????
    Regards.
    Default Re: send 9 bits via hserout
    To set 9-bit operations, use ...
    DEFINE
    HSER_TXSTA 64h
    Don't set parity unless you need that on your network, with less bits.
    The nineth bit is in TXSTA.
    TX9D VAR TXSTA.0
