How to use DT_INT with 12F683
Results 1 to 7 of 7
Threaded View
  1. #4
    Default Re: How to use DT_INT with 12F683
    Either you have a very old version of DT_INTS-14, or you're doing it in the wrong place.
    You shouldn't modify the include file.
    Make sure you have the latest version.
    http://www.darreltaylor.com/DT_INTS-14/downloads.htm
    added by Archangel 08/26/2015 http://web.archive.org/web/201305180.../downloads.htm
    Then in your program, copy the variables from the include and uncomment the wsaves you need for that program.
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines in the include                        --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
