Reference a port pin from a variable
Results 1 to 4 of 4
    Feb 2012
    Default Reference a port pin from a variable
    I know you can reference an I/O pin for a given port in a loop such as “PortC.0(idx)”. I was wondering if there was a similar way to reference pins from multiple ports in one loop. I am looking to access Pins from ports A, B, C, D, and E.
    Jim
    Default Re: Reference a port pin from a variable
    Looking at the datasheet for the 16F877 for example it shows that all the port registers are concecuitive in memory. So I think it'll work to just do something like
    FOR i = 0 to 34 35 bits (depending on how wide PortE is)
    TOGGLE PORTA.0[i]
    NEXT
    Just be careful so you don't write beyond the port registers and obviosuly there will be a "gap" at bits 6 and 7 of port A.
    Never tried it myself.
    Feb 2012
    Henrik,
    I was thinking the same thing might work, but haven't tried it yet. I will actually be getting the port index from eeprom data, so gaps and order won't matter. I will give it a try and let you know how it worked.
    Jim
    Feb 2012
    I just tried that suggestion and it worked.
    Jim
    TOGGLE PORTA.0[i]
    NEXT
