Help with two lookup tables?
Results 1 to 4 of 4
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Default Re: Help with two lookup tables?
    Hi awdgsx
    Just have a look to :
    http://www.picbasic.co.uk/forum/showthread.php?t=11212
    w
    here Darel explains in details how to use the EXT instruction to do what you want.
    Best regards
    MikeBZH
    Jun 2011
    So it's used like this?
    Define osc 20  'use 20 Mhz clock
    Define adc_bits 10
    Define ADC_CLOCK 3
    Define ADC_SAMPLEUS 24
    EEPROM [216, 0, 217, 0, 219, 0, 223, 0, 229, 0, 237, 0, 246, 0, 0, 1, 12, 1, _
    22, 1, 30, 1, 42, 1, 55, 1, 69, 1, 86, 1, 104, 1, _
    124, 1, 143, 1, 163, 1, 184, 1, 202, 1, 219, 1, 237, 1, 254, 1, 15, 2, _
    32, 2, 49, 2, 66, 2, 82, 2, 98, 2, 114, 2, 130, 2, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5_
    5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5_
    5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5 ,5 ,5 ,5 ,5 ,5 ,5 ,5 ,5 ,5]
    EEPROM 128, [146, 2, 161, 2, 177, 2, 192, 2, 207, 2, 222, 2, 237, 2, 252, 2, 11, 3, _
    26, 3, 40, 3, 55, 3, 70, 3, 84, 3, 99, 3, 113, 3, _
    128, 3, 142, 3, 156, 3, 170, 3, 183, 3, 197, 3, 210, 3, 223, 3, 236, 3, _
    249, 3, 255, 3, 255, 3, 255, 3, 255, 3, 255, 3, 255, 3, 0, 4]
    WRITECODE 0,0,19,24,38,48,58,66,77,80,96,110,115,200,234,250,254,300,_
              400,420,500,600,800,900,950,1000,1100,1200,1300,11400,1500,1600,_
              1700,1800,1900,2000,2100,2200,2300,2400,2500,2600,2700,2800,2900,_
              3000,3100,3200,3300,3400,3500,3600,3700,3800,3900,4000,4100,4200,_
              4300,4400,4500,4600,4700,4800,4900,5000,5100,5200,5300,5400,5500,_
              5600,5700,5800,5900,6000,6100,6200,6300,6400,6500,6600,_
              6700,6800,6900,7000,7100,7200,7300,7400,7500,7600,7700,7800,7900,_
              8000,8100,8200,8300,8300,8300,8300,8300,8300,8300,8300,8300,8300,_
              8300,8300,8300,8300,8300,8300,8300,8300,8300,8300,8300,8300,8300,_
              8300,8300,8300,8300,8300,8300,8300,8300,8300]
    mafin var Word  'analog input value
    flow var Word  'output value
    flowfinal var word
    mafout var word
    tempval var Word  'temporary
    tempval4 var word  'temporary 4
    tablehigh var Word  'high table value
    tablelow var Word  'low table value
    tablehigh2 var word
    tablelow2 var word
    tempval2 var Word  'temporary #2
    tempval3 var word   'temporary #3
    avgarray var Word[32]  'array for averaging input samples
    countnum var Byte  'integer for counting sample array
    arraysum var Word  'summing variable for average
    TRISA = 255  'portA => input
    ADCON1 = %10000010  'Set PORTA to analog and PORTE to digital
    TRISB = %00000000  'Port B set for output
    High PORTB.2  'Serial D-A chip select off
    countnum = 0
    clearloop:  'zero out array
    DOloop:  'start of main loop
    Adcin 0, mafin
    arraysum = arraysum - avgarray[countnum]  'subtract value at countnum
    avgarray[countnum] = mafin  'store new value in array
    arraysum = arraysum + mafin  'add to sum value
    mafin = arraysum > > 5  'divide by 32
    countnum = countnum + 1
    If countnum = 32 Then
    countnum = 0
    Endif
    tempval4 = mafin > > 3  'shift input for table lookup
    tempval3 = tempval4 & %1111111111111110  'clear last bit for WORD lookup
    READCODE tempval3 + 1, tablehigh
    READCODE tempval3 + 2, tablelow
    tempval4 = mafin & %0000000000001111  'get interpolation value
    If tablehigh >= tablelow Then  'get space between table values
    tempval3 = tablehigh - tablelow
    Else
    tempval3 = tablelow - tablehigh
    Endif
    tempval4 = tempval2 * tempval4  'multiply high/low diff by interp value
    outputval = tempval4 > > 4  'divide by table spacing
    If tablehigh >= tablelow Then  'offset table value by calculated
    flow = flow + tablelow  'interpolation value
    Else
    flow = tablelow - flow
    flowfinal=flow/2
    tempval = flowfinal > > 3  'shift input for table lookup
    tempval2 = tempval & %1111111111111110  'clear last bit for WORD lookup
    Read tempval2 + 2, tablehigh.byte0
    Read tempval2 + 3, tablehigh.byte1
    Read tempval2, tablelow.byte0
    Read tempval2 + 1, tablelow.byte1
    tempval = adval & %0000000000001111  'get interpolation value
    tempval2 = tablehigh - tablelow
    Else
    tempval2 = tablelow - tablehigh
    Endif
    tempval = tempval2 * tempval  'multiply high/low diff by interp value
    outputval = tempval > > 4  'divide by table spacing
    outputval = outputval + tablelow  'interpolation value
    Else
    outputval = tablelow - outputval
    Endif
    tempval = outputval < < 2  'shift output left 2 bits(LTC1661 DtoA)
    tempval = tempval + %1001000000000000  'add control code(load DAC A)
    Low PORTB.2  'Enable DtoA chip
    shiftout PORTB.0, PORTB.1, 1, [tempval\16]  'Serial output to DtoA conv
    High PORTB.2  'Deselect DtoA chip
    Goto loop  'repeat main loop "forever"
    Now i'm confused how to set up the output lookup table to convert the flow number from the first table back into a 10 bit numfor the dac?
    May 2009
    Awdgsx,
    If you want to write data (at programming) in the Flash program memory space you should open an ASM section in your code and use a DB or DW list of values, separated by commas. Please refer to lhe link I passed to you and follow Darrel Taylor's recommandations. This was my reference when I had to do the same thing. Everything is there.
    Mike BZH
