Re: DT_Ints-18
Results 1 to 5 of 5
Thread: Re: DT_Ints-18
    Jul 2005
    Midwest
    Default Re: DT_Ints-18
    I would like to try out Darrel Taylor's interrupts for the first time and would like to make sure this link leads to the current version which supports PBP3? The last update appears to have been about 4 years back. Thanks Darrel!
    http://darreltaylor.com/DT_INTS-18/home.html
    Because nobody's found a problem with it in the last 4 years.
    If you use MicroCode Studio, that one is fine.
    If you are using MPLAB or MPLAB X, there is a newer version ...
    http://support.melabs.com/threads/11...full=1#post415
    Jul 2005
    Midwest
    No surprise there! Wanted to be sure, running a recently clean install of my OS. I'm working with the new Microcode studio and UMC which is really slick.
    Thanks for all that you do and contribute on the list etc etc!
    Dec 2010
    Is this one backwards compatible? In other words will it still work with MicroCode Studio? (Just worried about tracking which is version where on my machine)
    Yes, it will work with MCS too.
