4x40 Lcd ?
Results 1 to 2 of 2
Thread: 4x40 Lcd ?
    Dec 2003
    San Diego
    Question 4x40 Lcd ?
    I need to interface a 4X40 LCD using the LCDOUT command.
    The LCD has two standard controllers.
    It has two enable pins to activate the controllers one at a time.
    All other lines are in parallel
    I have an interface that works great in MBasic but the commands in PicBasic are no way similar and the manual does not address how to control the enable pin except for a single controller.
    A simple code example will get me on the right track.
    Thanks....
    tcbcats
    Apr 2003
    Cambridge - UK
    Although there are some major differences between versions of PIC BASIC from different sources.
    generally there are some common issues that can be addressed similarly. This solution is listed on the Proton PICBASIC users site, but could be applied to an application written in PBP.
    http://users.picbasic.org/index.php?...todetail&id=33
  1. 16f688 LCD what have I done wrong
  2. LCD 4X40 Futurlec
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 8th April 2009, 04:35
  3. Play with LCD on PICDEM
  5. 4x40 LCD control problem
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 11:43
