Well, it's refreshing to learn something new. Anyway, here's the code that didn't come through earlier.
;This program will blink a light on portb.1 at a 1 hz rate   --
'with another LED on portd.1 blinking at a different rate
'different TMR1 preloads to get desired frequencies
wsave   VAR BYTE    $70     SYSTEM    ' alternate save location for W
wsave1  VAR BYTE    $A0     SYSTEM    ' location for W if in bank1
wsave2  VAR BYTE    $120    SYSTEM    ' location for W if in bank2
wsave3  VAR BYTE    $1A0    SYSTEM    ' location for W if in bank3
LED1   VAR  PORTB.1
led2   VAR portd.0
INCLUDE "DT_INTS-14.bas"    ' Base Interrupt System
INCLUDE "ReEnterPBP.bas"    ' Include if using PBP interrupts
DEFINE osc20
T1CON = %00000001                ; Prescaler = 1:1, TMR1ON
preload VAR WORD
preload = 61476 '60543 by MultiCalc should yields about 200Hz but
                '60643 yeilds exactly 100 Hz
                ' 48876 29.8cps
                ' 57209 yields 59.5cps
                ' 61376 yields
tmr1l = preload.LowByte
tmr1h = preload.HighByte
  PAUSE 500
  TOGGLE led2
  PAUSE 500
  TOGGLE led2
GOTO Main
'---[TMR1 - interrupt handler]------------------------------------
ToggleLED1:
           t1con.0 = 0
           t1con.0 = 1
     TOGGLE LED1
@ INT_RETURN
