PIC18f25k22 help with OSC configs
Results 1 to 5 of 5
    Nov 2006
    Default PIC18f25k22 help with OSC configs
    This is a case of trying too many new things at once. I'm using a PIC18f25k22 (a new device for me) with a standalone, 3-pin 20 Mhz oscillator (also new to me - see photo), and PBP 3 (new to everyone). Right now I'm just starting with a blinky program. I can flash an LED no problem using the internal oscillator, but when I try the external oscillator, the led flashes way too slow--about 20 times too slow to be more precise. If I change the DEFINE OSC statement from 20 to 4 the flashing speeds up, but it is still too slow. It is as if the oscillator is actually working at 1 Mhz instead of 20.
    Here is what works (internal oscillator):
    asm
          __CONFIG    _CONFIG1H, _FOSC_INTIO67_1H
          __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_INTMCLR_3H
          __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    endasm
    OSCCON  = 110000;                         ' 16mHz
    DEFINE OSC 16
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    TRISA = 0
    TRISB = 0
    TRISC = 0
    PORTA = 0
    PORTB = 0
    PORTC = 0
    FLASHLOOP:
    HIGH PORTB.4
    LOW PORTB.4
    PAUSE 500
    GOTO FLASHLOOP
    eND
    And here is what works way too slow:
    asm
          __CONFIG    _CONFIG1H, _FOSC_XT_1H
    endasm
    DEFINE OSC 20
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    TRISA = 0
    TRISB = 0
    TRISC = 0
    PORTA = 0
    PORTB = 0
    PORTC = 0
    FLASHLOOP:
    HIGH PORTB.4
    LOW PORTB.4
    PAUSE 500
    GOTO FLASHLOOP
    eND
    I'm hopeful that someone will see an obvious error. I've been playing around with configuration settings and datasheets, but I am far from exhausting all possible options.
    Nov 2006
    Default Re: PIC18f25k22 help with OSC configs
    Nevermind. Figured it out 5 minutes later. I needed to specify a high speed, high power oscillator and I had to turn off the clock multiplier thingy. In other words:
    _CONFIG _CONFIG1H, _FOSC_HSHP_1H & _PLLCFG_OFF_1H
    Alabama,USA
    Brid0030,
    I can’t see the connection with your EXT OSC CONFIG’S but there is a note in the OSC module section of the data sheet that says the default output freq of HFINTOSC is 1 Mhz. Did you include in your post all of your EXT OSC code?
    Wayne
    Nov 2006
    Not sure what you are getting at, Wayne. Yes, all the code is there. The 1 Mhz default condition might explain why the PIC seemed to operate at 1 Mhz when I specified the wrong OSC configuration (XT and not HFHP).
    Read his edit where he says oops!
