12F508 and Dallas 1820 not working
Results 1 to 14 of 14
    Feb 2012
    Default Re: 12F508 and Dallas 1820 not working
    Sorry, I forgot to mention, that I use internal oscillator, and I have set that when programming the chip. I use Epic to program the chip, and internal oscillator is selected there. I tested everything with simple led blink program and it worked ok. And as I mentioned, also the attached program starts fine. Led at GPIO.0 comes up for one second but the program never comes out from sensor routine (Temp_1). I have tested that by adding simple led on/off routine to before Goto Temp_1. So, my guess is, that I cannot configure the data pin (GPIO.1) right. I have used PortC.6 or PortC.0 when using 16F876A and those pins do not require any special configuration.
    Nov 2008
    If you are using the internal osc you might want to setup the osccon register. I don't see it in your code.
    CharlieM
    Using PBP3
    MCSPX
    Feb 2012
    Thanks.
    I do not know what OSCON has to do with this, because test program (led blink) works, so the program is running without any OSCON-setting. The orinal calibration value is there. The only problem is DS1820 sensor handling. The same read loop (Temp_1) works very well with 16F873 and 16F876A running 4 MHz. The only difference is that I use here GPIO.1 as DQ-pin instead of PortC.0 with those 16F series chips. Maybe I have to try to ask rentron.com, what is wrong with my code with 12F508.
    Nov 2008
    I may have been wrong. It looks as though this pic does not have a osccon register. I tried your code on a 12F683 and it did not work either.
    CharlieM
    Using PBP3
    MCSPX
    The first thing is to be sure of your sensor ID ...
    The second ... to be sure the bytes are transmitted in the right sequence ( not swapped )
    from this point of view ... why not try to write and read to it skipping this ID. That could point closer to the reason your code doesn't work ...
    Feb 2012
    Thank you again.
    The sensor ID is correct. I have tested the same sensor and the same piece of code with 16F876A using PortC.0, and I can read the sensor without any trouble. Hardware is ok, checked it carefully. Again my opinion is, that something is wrong with my code with GPIO.1. I am not an engineer, and I am not sure how these pins work in 12F508. When using 16F876A or 16F873 no special configuration is needeed. Just define:
    DQ var PortC.0
    and everything works.
    Dec 2008
    Ploiesti, ROMANIA
    Instead :
    TRISIO =%00000010 '???? maybe wrong?
    try :
    TRISGPIO + %00000010
    since I think don't exist TRISIO (see page 32 of datasheet : just TRISGPIO, TRISC, GPIO ....where GPIO is refferenced as PortB)
