Serial interrupt on PicBasic Pro
Results 1 to 3 of 3
    Default Re: Serial interrupt on PicBasic Pro
    I never use ON INTERRUPT myself and I haven't looked very closely at your code yet but the first thing that pops out is RCREG = DISCARD... Why do you write to RCREG?
    If you want to flush it you should read it, ie. DISCARD = RCREG
    Feb 2011
    You're right... i want to clean RCREG, so the right command is DISCARD = RCREG..
    I changed this but the problem still happens.
    /Regis
