Serial interrupt on PicBasic Pro
Results 1 to 3 of 3
    Feb 2011
    Default Serial interrupt on PicBasic Pro
    I need some help with this serial interrupt... It's working but not so well because when the interrupt happens I receive the serial data and treat the information. The problem is when the program return from the 1st interrupt to the Loop, I can't do another interrupt. I send serial data but the interrupt not happens.
    So, please, can anyone help me?
    Thanks...
    Here's my code..
    CONFIG_USART_INTERRUPT.txt
    Default Re: Serial interrupt on PicBasic Pro
    I never use ON INTERRUPT myself and I haven't looked very closely at your code yet but the first thing that pops out is RCREG = DISCARD... Why do you write to RCREG?
    If you want to flush it you should read it, ie. DISCARD = RCREG
    Feb 2011
    You're right... i want to clean RCREG, so the right command is DISCARD = RCREG..
    I changed this but the problem still happens.
    /Regis
