Send out file hex from chip to computer in PIC16F84A
Results 1 to 3 of 3
    erwin13's Avatar
    erwin13 Guest
    Wink Send out file hex from chip to computer in PIC16F84A
    dear all
    i'm new beginning in here,greetings knows,i need you help,i want to copy (save as) file hex from chip into computer so that can be burn with a same chip.how to Send out file hex from chip to computer in PIC16F84A
    thanks before for you attention
    Aug 2003
    Default Re: Send out file hex from chip to computer in PIC16F84A
    You'll have to read it with a pic programmer that still supports the 16F84a.
    I don't think the pickit II supports it.
    The good question is to know if the chip belongs to a hobbyist or has being bought ...
    In the first case ... may be the program can be read and saved ... IF it belongs to the programmer supported chips ( Pickit2 is Ok in standalone mode ... ! )
    In the second case ... probably the chip is read protected and it is not useful to loose time and/or money with it ...
