Wired remote for Alpine
Results 1 to 39 of 39
    Dec 2008
    Ploiesti, ROMANIA
    Default Wired remote for Alpine
    Hello !
    Since I have good results with "wired remote for Pioneer HU" (see : http://www.picbasic.co.uk/forum/showthread.php?t=15229 ) one friend ask me to build something similar for his Alpine ...
    I found a good topic here : http://www.mp3car.com/input-devices/...ol-pinout.html , where it's described the "protocol".
    I intend to use the same hardware : PIC 16F628A and remote control stalk near the steering wheel, from Renault.
    But...I need help to put in PBP this :
    Vol Up    110101111101101110101011110110111101011011010101
    Vol Dn    110101111101101110101011011011011111011011010101
    Mute    110101111101101110101011101011011110111011010101
    Pst up    110101111101101110101011101010111110111101010101
    Pst dn    110101111101101110101011010101011111111101010101
    Source    110101111101101110101011101101111101101101010101
    Trk up    110101111101101110101011101110111101101011010101
    Trk dn    110101111101101110101011010111011111101011010101
    Power    110101111101101110101011011101111110101101010101
    Ent/Play    110101111101101110101011010101111111110101010101
    Band/prog    110101111101101110101011011010111111011101010101
    Note that the same series of 1's and 0's is at the start and end of each command, so here are the unique parts of each:
    (Start)    110101111101101110101011
    Vol Up    11011011110101101
    Vol Dn    01101101111101101
    Mute    10101101111011101
    Pst up    10101011111011110
    Pst dn    01010101111111110
    Source    10110111110110110
    Trk up    10111011110110101
    Trk dn    01011101111110101
    Power    01110111111010110
    Ent/Play    01010111111111010
    Band/prog    01101011111101110
    (End)    1010101
    So if "0" is low for 1000 us, and "1" is high for 500 us AND low for 500 us, how can I write the code ?!
    Something like this (pseudo-code):
    ;(Start)    110101111101101110101011
     ; Vol Up    11011011110101101
    check: select case key  case 1     ; volume down
    portb.7 = high
    pauseus 500
    portb.7 = low
    pauseus 500  ' this is first "1"
    portb.7 = high
    pauseus 500
    port.7 = low
    pauseus 500 ' this is second "1"
    ... so on, so on ?!?
    I need "a clue" ! Thanks in advance !!!
    Default Re: Wired remote for Alpine
    Here's an idea:
    '*  Name    : Fratello_Alpine.PBP                               *
    '*  Author  : Henrik Olsson                                     *
    '*  Notice  :                                                   *
    '*  Date    : 2012-01-31                                        *
    ' CONFIGs and hardware setup, ADCON, CMCON, TRIS whatever not shown here.
    StartH CON %11010111        ' High 8 bits of start frame
    StartM CON %11011011        ' Middle 8 nits of start frame
    StartL CON %10101011        ' Low 8 bits of start frame
    VolUpH CON %11011011        ' High 8 bits of command
    VolUpM CON %11010110        ' Middle 8 nits of command
    VolUpL CON %11010101        ' Low bit of command + 7bits END of frame
    VolDnH CON %01101101        ' High 8 bits of command
    VolDnM CON %11110110        ' Middle 8 nits of command
    VolDnL CON %11010101        ' Low bit of command + 7bits END of frame
    ByteArray VAR BYTE[6]       ' 6 bytes = 48bits
    BitCount  VAR BYTE          ' Index variable for above array
    i         VAR BYTE          ' General purpose
    ' Initialise the first three bytes of the array, these are static.
    ByteArray[0] = StartH
    ByteArray[1] = StartM
    ByteArray[2] = StartL
    Pause 1000
    HSEROUT["Program start",13]
        For i = 0 to 20
            GOSUB VolumeUp
            Pause 300
        NEXT
        FOR i = 0 TO 20
            GOSUB VolumeDn
            Pause 300
        NEXT
        Goto Main
    ' Subroutines follows:
    VolumeUp:
        ' Set non static part of array to current command.
        ByteArray[3] = VolUpH
        ByteArray[4] = VolUpM
        ByteArray[5] = VolUpL
        GOSUB SendIt
    VolumeDn:
        ByteArray[3] = VolDnH
        ByteArray[4] = VolDnM
        ByteArray[5] = VolDnL
        GOSUB SendIt
    SendIt:
        FOR BitCount = 0 to 47
            If ByteArray.0[BitCount] = 1 THEN
                GOSUB One
                GOSUB Zero
        NEXT
    One:
        PORTB.7 = 1
        PAUSEUS 500
        PORTB.7 = 0
        PAUSEUS 500
    Zero:
        PortB.7 = 0
        PAUSEUS 1000
    Dec 2008
    Ploiesti, ROMANIA
    WOW !!! What fast and GREAT answer !!!
    Thank YOU so much ! I will try this and post feed-back !
    Dec 2008
    Ploiesti, ROMANIA
    One little queries : In "SendIt:" which is the command to send (to portb.7) the data from ByteArray[n] (n=3;4;5) ? I miss something ? Thanks !
    Not sure I understand what you mean....
    Send it iterates thru the bytearray bit by bit. For each bit it GOSUBS either One or Zero based on if the bit is 1 or 0. It's in the routines One and Zero that the actual port is written.
    With that said, the code is untested so I may have missed something.
    Dec 2008
    Ploiesti, ROMANIA
    I understand...Thanks !
    Next step : need confirmation if works correct (just VolumeUp & VolumeDn at this moment) !
    In attach : code and Proteus simulation.
    Dec 2008
    Ploiesti, ROMANIA
    Please, take a look at this two pictures ..."original" vs. testing ...
    In "our" case, after commander begins ("an 8ms pulse at +5V and then 4.5ms at 0V"), we have 11101011110...instead 1101011111 ...
    It looks to me like the :
    is getting read out backwards, as it is incrementing from bit 0 to 47. I think you need to change some things so it gets read out forward.
    http://www.scalerobotics.com
    Yeah, didn't think that one thru all the way - apparently. But you're smart enought to move things around so the bits come in the right order.
    Dec 2008
    Ploiesti, ROMANIA
    I reverse ... something, and the results are Ok (in Proteus) ! Hope to testing soon if work ! Thank You all ! I will post the results !
    ;StartH CON %11010111        ' High 8 bits of start frame
    StartH CON %11101011
    ;StartL CON %10101011        ' Low 8 bits of start frame
    StartL CON %11010101
    ;VolUpM CON %11010110        ' Middle 8 nits of command
    VolUpM CON %01101011
    ;VolUpL CON %11010101        ' Low bit of command + 7bits END of frame
    VolUpL CON %10101011
    Dec 2008
    Ploiesti, ROMANIA
    Mr.Henrik Olsson : THANK YOU ! With some minors modification (reversing order ; changes in KeyPad2.pbp ; adding input/output timming), the code work PERFECT !!!
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Ready for a new challenge ?! Just a joke, of course !
    I have all information about code for JVC remote : http://www.avforums.com/forums/car-e...l#post16560076
    The code is ... SO BIG ....
    This is how commands look :
    11111111000000000000000011111111
    01110111011101110101010111<C>0111
    11111111111111111111111111111111
    where the <C>s should be replaced by:
    0x04 Vol+                     01010111101010101
    0x05 Vol-                     01111010111101010101
    0x08 Source                   01010101111010101
    0x0D Sound                    01111010111101111010101
    0x0E Mute                     01011110111101111010101
    0x12 Skip fwd or Right        01011110101011110101
    0x13 Skip back or left        01111011110101011110101
    0x14 Skip fwd hold or Up      01010111101011110101
    0x15 Skip back hold or down   01111010111101011110101
    How #*&^%$#@"_)_ can write this in PBP ? I can figure out...Any help will be wellcome ! Thanks !
    Dec 2008
    Ploiesti, ROMANIA
    In front of each <Command> it's this : 00000000000000001111111101110111011101110101010111 <C>
    How can be writting, more "elegant" this :
    timp con 536
    portb.x = 0
    pauseus 8584 ; 16 x 536,5 us
    portb.x = 0
    pauseus 4292 ;   8 x 536,5 us
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610 ;   3 x 536,5 us
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610
    As last time this is completely untested. This builds and sends the command in steps which means that there will be some delay between the "preamble", "command" and "postamble". I don't know how tight the timing has to be so doing it this way may or may not work.
    '*  Name    : Fratello_JVC.pbp                                  *
    '*  Notice  :                                                   *
    '*  Date    : 2012-03-12                                        *
    i VAR BYTE
    j VAR BYTE
    OutBuffer VAR BYTE[8]
    BitsToSend VAR BYTE
        For j = 0 to 10
            GOSUB VolUp
            Pause 1000
        NEXT
        FOR j = 0 to 10
            GOSUB VolDn
            PAUSE 1000
        NEXT
    GOTO Main
    SendPreamble:
    ' 00000000  00000000  11111111  01110111 01110111 01010101  11
    ' Each individual byte reversed:
        OutBuffer[0] = %00000000
        OutBuffer[1] = %00000000
        OutBuffer[2] = %11111111
        OutBuffer[3] = %11101110
        OutBuffer[4] = %11101110
        OutBuffer[5] = %10101010
        OutBuffer[6] = %00000011
        BitsToSend = 50
        GOSUB SendBits
    SendPostAmble:
    ' 01111111 11111111 11111111 11111111 11110111 01110111 01110101 010111
        OutBuffer[0] = %11111110
        OutBuffer[1] = %11111111
        OutBuffer[3] = %11111111
        OutBuffer[4] = %11101111
        OutBuffer[5] = %11101110
        OutBuffer[6] = %10101110
        OutBuffer[7] = %00111010
        BitsToSend = 54
        GOSUB SendBits
    VolUp:
        GOSUB SendPreAmble
        ' 01010111 10101010 1
        OutBuffer[0] = %11101010
        OutBuffer[1] = %01010101
        OutBuffer[2] = %00000001
        BitsToSend = 17
        GOSUB SendBits
        GOSUB SendPostAmble
    VolDn:
        GOSUB SendPreAmble
        ' 01111010 11110101 0101
        OutBuffer[0] = %01011110
        OutBuffer[1] = %10101111
        OutBuffer[2] = %00001010
        BitsToSend = 20
        GOSUB SendBits
        GOSUB SendPostAmble
    SendBits:
        BitsToSend = BitsToSend - 1
        For i = 0 to BitsToSend
            PortB.0 = OutBuffer.0[i]
            PauseUs 536
        NEXT
    Again, not tested so take it for what it is.
    Dec 2008
    Ploiesti, ROMANIA
    WOW ! Amazing ! Thank YOU so much !!!
    I discover, every time when someone, like YOU, post such a great example of code, how far I am from understanding this great art of programming !!!
    I made the tests and post the results. Best regards !
    Dec 2008
    Ploiesti, ROMANIA
    I made some changes ....
    VolUp:
        GOSUB SendPreAmble
        OutBuffer[1] = %01010101  ; modified
        BitsToSend = 17
        GOSUB SendBits
        GOSUB SendPostAmble
            BitsToSend = 17
        GOSUB SendBits
        GOSUB SendPostAmble
            BitsToSend = 17
        GOSUB SendBits
        GOSUB SendFinalAmble
    and added this :
    SendFinalAmble:
    ' 01111111 11111111 11111111 11111111 11111111 11111111 11111111 111111
        OutBuffer[4] = %11111111
        OutBuffer[5] = %11111111
        OutBuffer[6] = %11111111
        OutBuffer[7] = %11111111
        BitsToSend = 54
        GOSUB SendBits
    ...and in Proteus look fine !
    Are you sure you actually have to send the command three times? Personally I have NO knowlage about these things but I would've guessed (if this is captured from a remote for example) that it just kept repeating the command and postamble untill the button was released and then issued the 'FinalAmble'. So perhaps Preamble, Command, FinalAmble is all you actually need? Oh well, like I said, I have no idea really - just guessing, you'll figure it out.
    Dec 2008
    Ploiesti, ROMANIA
    My informations are from one user of AVFORUMS.COM.
    "Every time you send the device and command codes, you should repeat the device and command codes three times, but pause between them for about 20ms." I think it's true...
    Dec 2008
    Ploiesti, ROMANIA
    Still beta-testing ...
    I wonder...It's one way to obtain EXACTLY 536.5 us ?!?
    Depends.... What's you oscillator speed? At 20Mhz an instruction cycles is 200ns so, in theory, doing something like
    PauseUs 536
    @ NOP
    @ NOP
    should get you pretty close (536.4us). If the timing is that critical then it's probably not going to work the way I wrote it since there will be "gaps" between the preamble, command, postamble etc. You'd need to build the complete message in a larger array and then send it but that gets a bit complicated due to the variation in length of the commands (they won't line up at even byte boundries).
    Dec 2008
    Ploiesti, ROMANIA
    Thank You for support !
    The oscillator is 4 MHz...
    Well, at 4Mhz each instruction cycle is 1us so the smallest time possible to resolve at that speed is just that - 1us. I don't think I can come up with any way to get higher resolution without increasing the oscillator speed.
    Dec 2008
    Ploiesti, ROMANIA
    Understand... so, maybe, I need a 20 MHz oscillator speed.
    But first - hardware test ! Best regards !
    Dec 2008
    Ploiesti, ROMANIA
    Mr.Henrik wrote the code...me just put together parts...
    BUT : even if in Proteus the signal(s) appears to be OK, the HU-JVC don't react at all !
    Maybe the "timming" need to be more accurate ?! At this point, I'm hopeless and stuck ... Any help will be appreciated !
    Hex and dns attached...
    ;*    Test variant, using 2N3904 on output - PORTC.0
    @ DEVICE PIC16F684, HS_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_OFF
    DEFINE OSC 20
    include "ALLDIGITAL.pbp"
    TRISA= 000011
    PORTA= 000011
    PORTC= 000000
    CMCON0 = 000111              ' Disable analog comparators.
    VRCON  = 000000               ' Disable Comparator Voltage Reference
    ANSEL  = 000000               ' Set pin'S to digital
    ADCON0 = 000000               ' Set up A/D converter - OFF
    Pause 1000
    i VAR BYTE
    j VAR BYTE
    BitsToSend VAR BYTE
    if porta.0 = 0 then gosub VolUp        ' just for test
    if porta.1 = 0 then gosub VolDn        ' just for test
    Pause 100                 ' do it for 0.1 sec
    Goto Main
    SendPreamble:
    ; 01110111 01110111 01010101 11
        OutBuffer[0] = 010001 ; 101110 REVERSED BECAUSE OF USING TRANSISTOR AT OUTPUT !!!
        OutBuffer[1] = 010001 ; 101110
        OutBuffer[2] = 010101 ; 101010
        OutBuffer[3] = 111100 ; 000011
        BitsToSend = 26
        GOSUB SendBits
    AGC:
    TRISC.0 = 1 ; 0
    PauseUs 8584
    TRISC.0 = 0 ; 1
    PauseUs 4292
    SendPostAmble:
        OutBuffer[0] = 000001 ; 111110
        OutBuffer[1] = 000000 ; 111111
        OutBuffer[2] = 000000 ; 111111
        OutBuffer[3] = 000000 ; 111111
        OutBuffer[4] = 110000 ; 001111
        BitsToSend = 36
        GOSUB SendBits
    SendFinalAmble:
        OutBuffer[4] = 000000 ; 111111
        OutBuffer[5] = 000000 ; 111111
        OutBuffer[6] = 000000 ; 111111
        OutBuffer[7] = 000000 ; 111111
        BitsToSend = 54
        GOSUB SendBits
    VolUp:
        Gosub AGC
        GOSUB SendPreAmble    ; one
        ' Volume Up
        OutBuffer[0] = 010101 ; 101010
        OutBuffer[1] = 101010 ; 010101
        OutBuffer[2] = 111110 ; 000001
        BitsToSend = 17
        GOSUB SendBits
        GOSUB SendPostAmble
        gosub SendPreamble    ; two
        ' Volume Up
        BitsToSend = 17
        GOSUB SendBits
        GOSUB SendPostAmble
        gosub sendPreamble    ; three
        ' Volume Up
        BitsToSend = 17
        GOSUB SendBits
    RETURN            ; end command
    VolDn:
        Gosub AGC
        GOSUB SendPreAmble
        ' Volume Down
        OutBuffer[0] = 100001 ; 011110
        OutBuffer[1] = 010000 ; 101111
        OutBuffer[2] = 110101 ; 001010
        BitsToSend = 20
        GOSUB SendBits
        GOSUB SendPostAmble
        GOSUB SendPreAmble
        ' Volume Down
        BitsToSend = 20
        GOSUB SendBits
        GOSUB SendPostAmble
        GOSUB SendPreAmble
        ' Volume Down
        BitsToSend = 20
        GOSUB SendBits
    SendBits:
            TRISC.0 = OutBuffer.0[i]
            PauseUs 536
            @ nop
            @ nop  ; for 536.5 us
        NEXT
    Like I said earlier, with this aproach you're going to get variation in the bit to bit timing when going from preamble to data to postamble etc. You should be able to SEE this on the scope. Also verify that you actually GET 536.4us between bits (I think it'll be a bit more due to the FOR-NEXT loop) and adjust the delay to match exactly.
    What I'd try, just to see IF timing is all there is to it is to stitch a complete packet together and send it in one go. Just extend the size of the array and load it up with bits, set BitsToSend accordingly and call SendBits.
    Dec 2008
    Ploiesti, ROMANIA
    You are such a fine gentleman !!! Thanks !
    ...so You say to put the entire command in "one place" ?
    OutBuffer[0] = ....
    to
    OutBuffer[n] = ....
    and
    BitsToSend = n x 8 GOSUB SendBits
    I have some doubt about how I understand this :
    "You really shouldn't drive the output line at 5V or 3V or any other voltage for a high output. If you want the output to be high, you do that by turning off the PIC's output driver. This way it doesn't matter what voltage the head unit uses, your hardware will always be compatible. It'll work at 5V, 3.3V, or anything.
    To do that, search the PIC manual for "Open-drain".
    For the 16-bit PIC24F series, you configure the pins as open drain by setting the bits in the ODCx register to '1's BEFORE you configure the pin as an output by writing '0's to the TRISx register."
    It's ok what I wrote in code, ie how I use PortC and TrisC ?
    Exactly, take the complete bitstream and fill the array with that, make sure you have the correct numbers of bits and then call SendBits. Because the actuall commads seem to be of different length the n*8 may not be true, make sure to count the actual number of bits in the packet.
    Regarding the other comment....It totaly depends on the actual hardware you're using but since you indicate that you're using a transistor between the PIC and the actual unit I think you need to DRIVE that transistor base high AND low, not float it by setting TRIS - again, depends on how your hardware is done.
    Dec 2008
    Ploiesti, ROMANIA
    Since I have no results with this code, I made this "PICKit2 IR capture tool" , from here : PIC Kit 2 IR capture tool « Spiralbrain's Blog
    The signals captured with this tool are totally different !!! I build even an IR widget for analyzing the IR signal...My conclusions : my remote, JVC RM-RK252, send a different code than that presented till now in this topic......I post the picture of all my captures, using AND an IR_Widget with IR_Scope (yes, I build this one too !)
    So : this is how the volume_up signal is ! The red part (in pdf) it's the part common for all commands ; the black part is proper command.
    Can I use Mr.Henrik examples for writting the new code ?! I have some questions : 415, 560 and 1400 are values by itselfs ...How can I put them in code ? Using something like this : "Data 560, 1400 ( this in hex ?), 560,1400,560,415,560,415, so on, so on ...." ?
    Thanks in advance for support and I apologize for my ignorance ...
    Dec 2008
    Ploiesti, ROMANIA
    Can be done in this way ???:
    ;          testing code for new JVC Remote
    ;                       march, 31
    @ DEVICE PIC16F684, HS_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_OFF, PROTECT_ON
    DEFINE OSC 20
    PORTA= 000011
    TRISA= 000011
    PORTC= 000000
    TRISC= 111110
    CMCON0 = 000111              'Disable analog comparators.
    ANSEL  = 000000               ' Set pin (AN2) to analog input, the rest to digital
    ADCON0 = 000000               ' Set up A/D converter - Right Just., VDD REF., CH 3, ON
    Pause 1000
    i VAR BYTE
    j VAR BYTE
    pulse con 560
    VolUp :
    TRISC.0 = 1
    pauseus 4000
    TRISC.0 = 0
    pauseus 1900
    TRISC.0 = 1
    pauseus pulse
    TRISC.0 = 0
    pauseus 1400
    TRISC.0 = 1
    pauseus pulse
    TRISC.0 = 0
    pauseus 1400
    TRISC.0 = 1
    pauseus pulse
    for i = 0 to 30
              Lookup i,[$BE,$8C,$8C,$2A,$2A,$2A,$2A,$2A,$2A,_
                        $8C,$2A,$2A,$2A,$2A,$2A,$2A,$2A,$2A,_
                        $8C,$2A,$2A,$2A,$8C,$2A,$2A,$2A,$2A,_
                        $2A,$2A,$8C,$8C] ,j
    TRISC.0 = 0
    PauseUs j*10
    TRISC.0 = 1
    PauseUs pulse
    next i
    In Proteus it's ok ; just the "preamble" part so far.
    Any advice will be wellcome !
    Dec 2008
    Ploiesti, ROMANIA
    This code :
    i VAR BYTE
    j VAR BYTE
    pulse con 560
    if porta.0 = 0 then  gosub volup
    TRISC.0 = 1
    VolUp :
    Gosub Preamble
    FOR I = 0 TO 17
                Lookup i,[$8C,$2A,$2A,$8C,$2A,$2A,$2A,$8C,$2A,$8C,_
                          $2A,$2A,$2A,$2A,$8C,$8C,$8C,$8C ] ,j
    TRISC.0 = 0
    PauseUs j*10
    TRISC.0 = 1
    PauseUs pulse
    next i
    PauseUs 4500
    Preamble :
    TRISC.0 = 1
    Pauseus 4000
    for i = 0 to 30
                        $8C,$2A,$2A,$2A,$8C,$2A,$2A,$2A,$2A,$2A,$2A,_
                        $8C,$8C ] , j
    TRISC.0 = 0
    PauseUs j*10
    TRISC.0 = 1
    PauseUs pulse
    next i
    give me, in Proteus (!), the code I need ...The next step it's hardware testing !
    Dec 2008
    Ploiesti, ROMANIA
    I put all the values into one command :
    pulse con 567
    MAIN :
    if porta.0 = 0 then
    PORTC.0 = 0
    pauseus 4032
    for i = 0 to 48
    lookup i,   [value, value, value, ....], j
    PORTC.0 = 1
    PauseUs j
    PORTC.0 = 0
    PauseUs pulse
    next i
    PORTC.0 = 0
    PauseUs 4500
    PORTC.0 = 1
    PAUSE 25
    ...but testing hardware I have no results , despite the "full similarity" with code captured with IR_Scope !
    Somebody has more experience with IR remote control ? It's the "lenght" of each pulse so critical ?
    I don't understand what I do wrong ...
    Dec 2008
    Ploiesti, ROMANIA
    Still no good news ... Cycle " for ...next" generate a "big" delay ?
    Aug 2008
    Portugal
    Hi fratello;
    I dind't read the hole thread, but are you trying to reproduce a IV remote control??
    If so, i see on your last post that your reproducing the pulses, but you are not using modulation, and you must use modulation when using IV. Probably 36Khz, or 38Khz, or 40Khz.
    Thanks and Regards;
    Gadelhas
    The actual FOR-NEXT construct will add some additional delay due to the fact that it is a jump isntruction and it has to make the comparison. Add to that the execution time of the LOOKUP instruction you're using. Why don't you just measure it and adjust the pulse constant so it matches the capture of the working remote?
    Dec 2008
    Ploiesti, ROMANIA
    Thanks !
    @Gadelhas : I try to build a wired-remote, not IR remote ; I use IR remote just for reading codes, but I intend to use wired - steering wheel - remote.
    @Henrik : Good ideea !!! I will try tomorrow to read MY signal ...by putting one LED to PIC output (?!)
    Dec 2008
    Ploiesti, ROMANIA
    I make reverse-engineering ... I put one IR-LED on output (driving by transistor) to see how the code work !
    And... surprise ! It's totally different by Proteus simulation and my whis !!!
    Despite I try to "PauseUs 560" the Pauseus, measured in IR_Scope, it's 202 to 208 us !
    I read this : "PAUSEUS assumes an oscillator frequency of 4MHz ;PAUSEUS 1000 ' Delay for 1 millisecond "
    It's not applicable on my code ?! Why ? I use an 4 MHz crystal , I define "XT_OSC" ... I really don't understand ...
    Are you sure that it is a 4Mhz and not a 10Mhz crystal?
    Do you have the correct capacitors inplace to load the crystal?
    Try something like
    TRISC.0 = 0
      PortC.0 = 1
      Pauseus 1000
      PortC.0 = 0
      Pauseus 1000
    Goto Main
    What's the frequency of the output signal?
    Dec 2008
    Ploiesti, ROMANIA
    Unfortunately, I dont have an oscilloscope ...I use just software tools, which are not so accurate !
    I capture the signal with OSCILLOSCOPE V1.40 and it's ok (measuring all pulses and pauses, dont know how accurate)...
    I am in big deadlock ! I don't know what else I can do.
    Hi! I am from Turkey. Taken in the forum I read that you are running on the remote control for Alpine.What did you use microcontrollers. I worked very hard, but did not succeed. Can you give pbp code for alpine? My adress is [email protected] Thanks.
    Quote Originally Posted by fratello View Post
