Wired remote for Alpine
Results 1 to 39 of 39
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Wired remote for Alpine
    I reverse ... something, and the results are Ok (in Proteus) ! Hope to testing soon if work ! Thank You all ! I will post the results !
    ;StartH CON %11010111        ' High 8 bits of start frame
    StartH CON %11101011
    StartM CON %11011011        ' Middle 8 nits of start frame
    ;StartL CON %10101011        ' Low 8 bits of start frame
    StartL CON %11010101
    VolUpH CON %11011011        ' High 8 bits of command
    ;VolUpM CON %11010110        ' Middle 8 nits of command
    VolUpM CON %01101011
    ;VolUpL CON %11010101        ' Low bit of command + 7bits END of frame
    VolUpL CON %10101011
    Dec 2008
    Ploiesti, ROMANIA
    Mr.Henrik Olsson : THANK YOU ! With some minors modification (reversing order ; changes in KeyPad2.pbp ; adding input/output timming), the code work PERFECT !!!
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Ready for a new challenge ?! Just a joke, of course !
    I have all information about code for JVC remote : http://www.avforums.com/forums/car-e...l#post16560076
    The code is ... SO BIG ....
    This is how commands look :
    11111111000000000000000011111111
    01110111011101110101010111<C>0111
    11111111111111111111111111111111
    where the <C>s should be replaced by:
    0x04 Vol+                     01010111101010101
    0x05 Vol-                     01111010111101010101
    0x08 Source                   01010101111010101
    0x0D Sound                    01111010111101111010101
    0x0E Mute                     01011110111101111010101
    0x12 Skip fwd or Right        01011110101011110101
    0x13 Skip back or left        01111011110101011110101
    0x14 Skip fwd hold or Up      01010111101011110101
    0x15 Skip back hold or down   01111010111101011110101
    How #*&^%$#@"_)_ can write this in PBP ? I can figure out...Any help will be wellcome ! Thanks !
    Dec 2008
    Ploiesti, ROMANIA
    In front of each <Command> it's this : 00000000000000001111111101110111011101110101010111 <C>
    How can be writting, more "elegant" this :
    timp con 536
    portb.x = 0
    pauseus 8584 ; 16 x 536,5 us
    portb.x = 0
    pauseus 4292 ;   8 x 536,5 us
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610 ;   3 x 536,5 us
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus timp
    portb.x = 0
    pauseus 1610
    As last time this is completely untested. This builds and sends the command in steps which means that there will be some delay between the "preamble", "command" and "postamble". I don't know how tight the timing has to be so doing it this way may or may not work.
    '*  Name    : Fratello_JVC.pbp                                  *
    '*  Author  : Henrik Olsson                                     *
    '*  Notice  :                                                   *
    '*  Date    : 2012-03-12                                        *
    i VAR BYTE
    j VAR BYTE
    OutBuffer VAR BYTE[8]
    BitsToSend VAR BYTE
        For j = 0 to 10
            GOSUB VolUp
            Pause 1000
        NEXT
        FOR j = 0 to 10
            GOSUB VolDn
            PAUSE 1000
        NEXT
    GOTO Main
    SendPreamble:
    ' 00000000  00000000  11111111  01110111 01110111 01010101  11
    ' Each individual byte reversed:
        OutBuffer[0] = %00000000
        OutBuffer[1] = %00000000
        OutBuffer[2] = %11111111
        OutBuffer[3] = %11101110
        OutBuffer[4] = %11101110
        OutBuffer[5] = %10101010
        OutBuffer[6] = %00000011
        BitsToSend = 50
        GOSUB SendBits
    SendPostAmble:
    ' 01111111 11111111 11111111 11111111 11110111 01110111 01110101 010111
        OutBuffer[0] = %11111110
        OutBuffer[1] = %11111111
        OutBuffer[3] = %11111111
        OutBuffer[4] = %11101111
        OutBuffer[5] = %11101110
        OutBuffer[6] = %10101110
        OutBuffer[7] = %00111010
        BitsToSend = 54
        GOSUB SendBits
    VolUp:
        GOSUB SendPreAmble
        ' 01010111 10101010 1
        OutBuffer[0] = %11101010
        OutBuffer[1] = %01010101
        OutBuffer[2] = %00000001
        BitsToSend = 17
        GOSUB SendBits
        GOSUB SendPostAmble
    VolDn:
        GOSUB SendPreAmble
        ' 01111010 11110101 0101
        OutBuffer[0] = %01011110
        OutBuffer[1] = %10101111
        OutBuffer[2] = %00001010
        BitsToSend = 20
        GOSUB SendBits
        GOSUB SendPostAmble
    SendBits:
        BitsToSend = BitsToSend - 1
        For i = 0 to BitsToSend
            PortB.0 = OutBuffer.0[i]
            PauseUs 536
        NEXT
    Again, not tested so take it for what it is.
    Dec 2008
    Ploiesti, ROMANIA
    WOW ! Amazing ! Thank YOU so much !!!
    I discover, every time when someone, like YOU, post such a great example of code, how far I am from understanding this great art of programming !!!
    I made the tests and post the results. Best regards !
    Dec 2008
    Ploiesti, ROMANIA
    I made some changes ....
    VolUp:
        GOSUB SendPreAmble
        OutBuffer[1] = %01010101  ; modified
        BitsToSend = 17
        GOSUB SendBits
        GOSUB SendPostAmble
            BitsToSend = 17
        GOSUB SendBits
        GOSUB SendPostAmble
            BitsToSend = 17
        GOSUB SendBits
        GOSUB SendFinalAmble
    and added this :
    SendFinalAmble:
    ' 01111111 11111111 11111111 11111111 11111111 11111111 11111111 111111
        OutBuffer[4] = %11111111
        OutBuffer[5] = %11111111
        OutBuffer[6] = %11111111
        OutBuffer[7] = %11111111
        BitsToSend = 54
        GOSUB SendBits
    ...and in Proteus look fine !
    Hi! I am from Turkey. Taken in the forum I read that you are running on the remote control for Alpine.What did you use microcontrollers. I worked very hard, but did not succeed. Can you give pbp code for alpine? My adress is [email protected] Thanks.
    Quote Originally Posted by fratello View Post
