Writing and reading bits and memory
Results 1 to 12 of 12
    Jan 2010
    Default Writing and reading bits and memory
    Hi Guys,
    Having a little problem with my code and can’t seem to see where the problem lies. Here’s what I’m trying to do. I have two inputs, a record button and two outputs. What I’ve attempted so far in my code is that when the record button is pressed, the program samples both inputs (inputs are driven high and pulled low) and writes the value in eeprom in bits at timed intervals. Because you cannot read and write to the eeprom in bits, I’ve created a routine that when in record mode, puts each bit value (1 or 0) in a temporary array and when the array is filled, that array is written to a memory position until the allotted memory space is filled or the program button is released. Recording time has a limit, however can be stopped at anytime.
    Once released, the program now plays back what was just recorded. It takes the byte array from memory and places it in a temporary array. The program reads and displays each bit until all 8 bits are read and then grabs the next byte array.
    Seems pretty simple and straight forward, however, I am getting unpredictable results. When I setup the circuit and program the chip, it does what it’s supposed to do when entering program mode, however, playback is playing back some of what I entered and then stuff I never entered.
    I setup the inputs as tactile switches for manual operation. My test consisted of simply alternating presses from left to right. What is repeated is the same alternating LEDs and then both will flash on at once at random intervals. When I hold down one button, I should get a continuous replay of one LED lit, so it looks like it has constant power. Instead I get something weird. If I record a button press on gpio.1 for 3 seconds, then I get LED1 (gpio.5) on for 3 seconds and then both come on for 1 second and then back to LED1 on for 3 seconds. However, if I record a button press on gpio.2 for 3 seconds, then I get LED2 (gpio.4) on for 3 seconds and then both LEDs are out for 1 second and then back to LED2 on for 3 seconds. What is my code doing?
    Shouldn’t each recording session overwrite each bit as I am writing over it? Can someone take a look and see what I’m missing? The circuit should sample the two inputs. They are always high unless pulled low. It should then take each value, put it into bit location 0, wait 100 ms and then repeat, but this time putting the next value into bit location 1 and so on until 7 is reached. When all 8 bits have filled the array, that temporary array writes it to memory (L_state[0] or R_state[0]). I allotted 30 bytes for each array in memory for this (runtime is about 24 seconds of recording). A counter assigns each location. On playback, the routine is reversed. The program reads L_state[0] or R_state[0], places each byte array into their own temporary array (leftvalue and rightvalue) and then reads each bit from 0 to 7 and displays it on the outputs at the same timed interval. In essence mimicking what the inputs were doing.
    I am using a 12F683 which has 128 bytes of RAM and 256 bytes of eeprom. I am running PBP 2.60. Any help would be greatly appreciated.
    ' -----[ Initialization ]--------------------------------------------------
     Reset:
        OPTION_REG.7    = 0          ' Pullups  enabled
        WPU             = 0000       ' Weak Pull Up
        GPIO            = 0000       ' sets outputs as high (1) or low (0)
        TRISIO          = 1111       ' sets pin as input (1) or output (0)
        ANSEL           = 0          ' Disable analog inputs
        CMCON0          = 7          ' Disable comparators
    leftvalue and rightvalue are the temporary arrays for reading and writing the bits for the arrays.
    ' -----[ Variables ]-------------------------------------------------------
        record        var   gpio.0    ' program button input
        leftbutton    var   gpio.1    ' left button input
        rightbutton   var   gpio.2    ' right button input
        rightled      var   gpio.4    ' right led output
        leftled       var   gpio.5    ' left led output
        leftvalue     var   byte      ' stores the opposite value of the button
        rightvalue    var   byte      ' stores the opposite value of the button
        counter       var   word      ' counts how many bits are being used
        limit         var   word      ' stores the last count value for the loop
        L_state       var   byte[29]  ' create 232 bits for storing 90 seconds
        R_state       var   byte[29]  ' worth of patterns for both left and right leds
        x             var   byte      ' variable for bit count
        y             var   byte      ' loop variable for output flash
    Here is where the writing occurs. Because the inputs are high and pulled low, I had to invert the value stored so it would reflect a button press and not the value.
    ' -----[ Program ]---------------------------------------------------------
    flash:
        for y = 1 to 3                ' flash outputs three times
            high leftled
            high rightled
            low leftled
            low rightled
        next y
        counter = 0                   ' reset counter value to 0
    program:
    while record = 0                  ' while record button is pressed, loop here
        if counter = 30 then finish   ' if 24 seconds is reached, exit program mode
        For x = 0 to 7
        if leftbutton = 0 then        ' if left buttton has been pressed,
            leftvalue.0[x] = 1        ' then write an "on" value
            leftvalue.0[x] = 0        ' then write an "off" value
        leftled = leftvalue.0(x)    ' display on led
        if rightbutton = 0 then       ' if right button has been pressed,
            rightvalue.0[x] = 1      ' then write an "on" value
            rightvalue.0[x] = 0      ' then write an "off" value
        rightled = rightvalue.0[x]  ' display on led
        pause 100                     ' pause 1/10th of a second
        next x
        write L_state[counter], leftvalue
        write R_state[counter], rightvalue
        counter = counter + 1         ' advance counter by 1
        goto program
    wend
        limit = counter               ' write counter value to limit
    goto action                       ' return to action
    Here's where the reading happens.
    ' -----[ Action ]----------------------------------------------------------
    action:
        FOR counter = 0 TO limit      ' start reading bit locations
        read L_state[counter], leftvalue  ' read the array of bits and place in left value
        read R_state[counter], rightvalue ' read the array of bits and place in right value
            for x = 0 to 7
            leftled = leftvalue.0[x]    ' left led will mimic bit value
            rightled = rightvalue.0[x]  ' right led will mimic bit value
            next x
        if record = 0 then program  ' If program button is pressed, then
                                             ' goto program mode
        NEXT counter
        goto action
    This is where the program goes if the time limit is exceeded.
    ' -----[ Exit Program ]----------------------------------------------------
    finish:
    while record= 0                   ' loop here while program button is held
            low leftled
            low rightled
        pause 500                     ' just wait 1/2 a second
        goto finish                   ' continue loop
    wend                              ' exit loop when button is released
        limit = 29                    ' write counter value to limit
    I know this seems like a lot of stuff when attempting to implement this program, however, this coding is modified from another program I wrote that is presently working. I merely substituted the bit writing in the appropriate places to get more "recording time". The other program worked perfectly, but with less "recording time".
    Tony
    Default Re: Writing and reading bits and memory
    Ater each write to eeprom, place a "PAUSE 6". This will allow enough time for the write to complete for that byte. Let us know...
    EN82fn
    (stuff removed)
    Ok, it's all in my edits now.
    EDIT: You said your previous version worked, did you have a delay in that version and then took it out?
    EDIT SOME MORE: Is there a particular reason why you use those GOTO at the end of both WHILE RECORD=0?
    EDIT YET AGAIN: by the way, byte[29] will create elements 0 thru 28. Writing element 29 will write "somewhere", but most likely not where you want.
    EDIT ONE LAST TIME: I'm curious, just how fast are you on those buttons anyways? You loop 29 times with a 10th of a second each loop, you gotta be pretty quick! That's just under 3 seconds to enter all those key presses isn't it? (or did I miss something?)
    Jan 2010
    Hi Dave,
    Tried the pause after each write command and now it's behaving even worse.
    Hi Demon,
    My last version I used wrote to bytes and not bits. Only got about 20 seconds (max) of record time. Was trying to extend it by writing to bits. I chose 29 bytes (about 24 seconds worth of recording) because I wanted to test the max out feature and was saving time by setting a lower limit. Once the code works, then I will increase the time.
    As for the goto; you know, that is kind of redundant. It automatically does that with the while..wend loop. I must have done that for some other code in the past and just didn't think anything about it. I will correct that and see if it does anything.
    I will fix the 29 bytes address, however, that should only be an issue when you max out the count, correct? If I only record for 3 seconds, I shouldn't get the playback I'm getting. Will fix that as well.
    As for the 29 bytes and 100ms pauses; I'm trying to record inputs of varying lengths. The best way I know how is to test the inputs multiple times per second. That way if I press the left input or right input or both at varying lengths, it should be able to repeat that the left button was held for 7/10 of a second while the right was held for 9/10 of a second. 1/10 of a second come out to 8/10 of a second per byte. 29 bytes is 24 seconds. I will be increasing that time by increasing the bytes being used, however limited the time for testing purposes. That, at least, was my logic.
    Tony
    Robert, The last time I did the math, 30 x 8 x .1 is more than 3 seconds....
    EN82fn
    Tony, Is what you are showing us the complete code? Do you have any interrupts enabled?
    EN82fn
    Bingo!
    I forgot the FOR loop.
    Jan 2010
    Yes it is. No interrupts. The only thing I noticed is that the "%00" was removed from my Initialization screen. Per the recommendations, L_state and R_state have been changed to 30 bytes and Counter has been changed to 31 instead of 30 in the program loop and pause 6 has been added after the write commands.
    The removal of the two goto's did help fix some irratic behavior, but still having the same problem of not playing back correctly.
    Tony
    Jan 2012
    Grid EN19MV
    Just a random thought here.
    I'm very new to PBP (but not to microcontrollers, or BASIC for that matter), but I really don't see anywhere that you are debouncing your switches. Could this be as simple as garbage getting in from bounce?
    Or am I missing something (usually the case.....)
    Jan 2010
    True, but that does not explain when holding down one button for a constantly lit LED that both will flash. I used this setup on my other program that wrote to bytes instead of bits, and it worked flawlessly.
    Tony, Please attach the entire program in 1 segment for our viewing from configs to end...
    EN82fn
    Jan 2010
    OK. Completed the code and things are working great now. Thanks to Darrel (DT), he explained a few things that I was doing wrong and clarified my understanding of what I thought was happening and what was really happening. After a few days of trial and error, I got it working perfectly. To clear up where the problem were, the following changes were made.
    1) Didn't need to make two arrays (L_state and R_state). One array served just fine and a (+ 1) went on the second byte values so that all the left inputs went into the even memory slots and the right inputs went into the odd memory slots.
    2) There was no need for four lines of code to invert the input value. The ! command took care of that (leftvalue.0[x] = !leftbutton)
    3) Wasn't writing my limit to eeprom, so the value erased itself when power was removed.
    So the major changes are:
    EE_Limit DATA  @254,WORD 0
     Reset:
        WPU             = %000000     ' Weak Pull Up disabled because of my external pullups
        TRISIO          = %001111     ' sets pin as input (1) or output (0)
    action:
        READ EE_Limit , WORD limit
        FOR counter = 0 TO limit Step 2' start reading bit locations
            read counter, leftvalue   ' read the array of bits and place in left value
            read counter + 1, rightvalue' read the array of bits and place in right value
            for x = 0 to 7
            next x
            if record = 0 then flash  ' If program button is pressed, then
                                      ' goto program mode
        NEXT counter
        goto action
    flash:
            high leftled
            high rightled
            low leftled
            low rightled
        next y
    program:
            if record = 1 then action ' if the program button was momentarily pressed,
                                      ' return to action loop
            if counter = 60 then finish ' if 24 seconds is reached, exit program mode
            for x = 0 to 7
                leftvalue.0[x] = !leftbutton ' store inverted value of leftbutton
                leftled = leftvalue.0[x]     ' display on led
                rightvalue.0[x] = !rightbutton ' store inverted value of rightbutton
            next x
            write counter, leftvalue
            write counter + 1, rightvalue
            counter = counter + 2     ' advance counter by 2
        wend
        limit = counter - 2           ' write counter value to limit
        WRITE EE_Limit , WORD limit
    goto action                       ' go to action and run pattern
    finish:
        while record = 0               ' loop here while program button is held
            low leftled
            low rightled
