HSEROUT Disable
Results 1 to 3 of 3
Thread: HSEROUT Disable
    Default HSEROUT Disable
    Is there any way to disable the hserout function once it's set in place with DEFINES? I found that the pins assigned to the hardware function cannot be used for anything else.
    [QUOTE'Define hserout parametersDEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 2400
    DEFINE HSER_CLROERR 1 'clear overflow error
    APFCON.7 = 1 'rx on ra1 (16f1823)
    APFCON.2 = 1 'tx on pin ra0 (16f1823) ][/QUOTE]
    I use hserout briefly at the start of my program. Later, I would to use pin RA0 for something else, but the circuit does work. Oddly, the debug function does not have any problem with this kind of switching.
    Default Re: HSEROUT Disable
    Try something like
    SPEN VAR RCSTA.7    ' Serial port enable
    USART_OFF:
    SPEN = 0
    USART_ON:
    SPEN = 1
    You MAY (but I don't think it's neccessary) also need to toggle the TXEN-bit, it's in the TXREG somewhere...
    Henrick,
    Your suggestion worked.
    It's the TX pin that I wanted to free up after using hersout at the top of my program. So, I inserted this line.
    TXSTA.5 = 0 'disable transmit function.
    Later, the function is re-enabled:
    TXSTA.5 = 1
    I should have read the data sheet more carefully.
    Dick
