Well, I think the problem is finally solved! The problem was indeed the lack of a filter algorithm. Searching about this kind of issue I´ve found this: http://www.pbpgroup.com/modules/wfse...hp?articleid=7
This algorithm by Darrel Taylor solved the false deployment in my circuit.
I just changed the number of averaged samples from 16 to 8. Now I can fullfill my eeprom using the desired amount of time on "PAUSE" depending on the interval between samples I need.
This problem I think is solved, but you know how things go with programming... I´ll keep looking for bugs before I breadboard it and finally build the final circuit.
I´d still appreciate any comments and sugestions on my code. An "outsider" always has better view than the author himself (looking the same code for hours and hours...).
Thanks guys!!
