If you plan to change from the 877A to something else I recommend 18F4620 (which is also pin-compatible). That will give you 64K Flash and alot more RAM. The only reason the 452 would be an option is if you cant get the 4620.
Do not worry about changing from the 877A, the 4620 is still easy to handle and has multiple INT inputs that you will find really useful.
