16bit variable and degrees conversion
Results 1 to 8 of 8
    Default Serin2 help
    Hmm looks that I'm doing something wrong
    I receive serial at 9600 bd N8,1 the following in hex
    example:
    21 AD 34 01 22 EF 23 02
    loop:
    AZ var word
    EL var Word
    Serin2 portb.2,84,[wait ("!"),AZ] => "!" is the ascii represenataion of 21 hex
    would like to store AD 34 in variable AZ, 01 dont care
    then the same for EF 23 in EL
    Use an SP485 RS485 driver in front
    Italy
    Your example data:
    ' The code (Not tested)
    my_array VAR BYTE[7] ' Define array variable with 7 locations
    SERIN2 IN_PIN, BAUD,[WAIT("!") STR my_array\7]
    ' Waits for the string "!", then collects the next 7 characters.
    ' (21 HEX = ASCII !)
    This could be valid data:
    21 21 21 01 22 21 21 02
    Make sure you verify that "01" "22" "02" are in the
    right position in the array.
    From PicBasic manual:
    An optional Timeout and Label may be included to allow the program
    to continue if a character is not received within a certain amount of time.
    Timeout is specified in 1 millisecond units. If the serial input pin stays in
    the idle state during the Timeout time, the program will exit the SERIN2
    command and jump to Label.
    PicBasic Pro Code that demonstrates the use of modifiers
    with the Serin2 and Serout2 commands.
    http://www.microengineeringlabs.com/...bp/ser2mod.bas
    Luciano
    Default Thanks
    Everything is working
    I would like to thank those who post some replys
    If someone is in the Belgian Area, I will certainly offer a Beer
    Walter
  1. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
