16bit variable and degrees conversion
Results 1 to 8 of 8
    Post
    IntPartOfPos1 = 16bitPosition1 ** 360
    FracPartOfPos1 = 16bitPosition1 * 360
    FracPartOfPos1 = FracPartOfPos1 ** 1000
    LCDOUT DEC3 IntPartOfPos1, ".", DEC3 FracPartOfPos1
    The code above starts with two multiplications by 360, one of them isn't really necessary. However i'm a bit unsure of wich internal register contains what after a multiplication. I think the code below will work, but i'm not 100% sure it's the right register. Try it and see.
    IntPartOfPos1 = R0
    /Ingvar
    Italy
    Hi!
    What precision do you need?
    Describe your project.
    The three conversions below (44340, 13107 and 13)
    are performed using the solution of the user Ingvar.
    (See his previous post).
    From the PicBasic Pro manual:
    PicBasic Pro multiply (*) function
    operates as a 16-bit x 16-bit multiply
    yielding a 32-bit internal result.
    4.17.1. Multiplication
    PBP performs unsigned 16-bit x 16-bit multiplication.
    The '*' operator returns the lower 16 bits of
    the 32-bit internal result. This is the typical
    multiplication found in most programming languages.
    The '**' operator returns the upper 16 bits of
    the 32-bit internal result. These two operators
    can be used in conjunction to perform 16-bit x 16-bit
    multiplication that produces 32-bit results.
    (See original post of the user Walter/RFsolution)
    With the Windows calculator:
    65535/360 = 182.04166666666666666666666666667
    44340 conversion
    44340 * 360 = 15962400
    15962400 = 00000000111100111001000100100000 (32-bit internal result)
    -----------0000000011110011-1001000100100000
    -------------(upper 16 bits )-----(lower 16 bits )
    Upper 16 bits of the 32-bit internal result = 0000000011110011 = 243 decimal
    Lower 16 bits of the 32-bit internal result = 1001000100100000 = 37152 decimal
    37152 * 1000 = 37152000
    37152000 = 00000010001101101110010100000000 (32-bit internal result)
    -----------0000001000110110-1110010100000000
    Upper 16 bits of the 32-bit internal result = 0000001000110110 = 566 decimal
    Lower 16 bits of the 32-bit internal result = 1110010100000000 = 58624 decimal
    Display = 243.566
    44340 / 182.04166666666666666666666666667
    = 243.57061112382696269169146257725
    13107 conversion (65535/5 = 13107 ---- 360 / 5 = 72 degrees)
    44340 * 360 = 4718520
    4718520 = 10001111111111110111000
    1000111-1111111110111000
    (up.part)---(lo. part)
    Upper part 1000111 = 71 decimal
    Lower part 1111111110111000 = 65464 decimal
    65464 * 1000 = 65464000
    65464000 = 11111001101110011011000000
    1111100110-1110011011000000
    Upper part = 1111100110 = 998 decimal
    Lower part = 1110011011000000 = 59072 decimal
    Display = 71.998
    13107 / 182.04166666666666666666666666667
    = 72
    13 conversion
    13 * 360 = 4680
    4680 = 0-0001001001001000
    -------(up.part)---(lo. part)
    Upper part 0 = 0 decimal
    Lower part 1001001001000 = 4680 decimal
    4680 * 1000 = 4680000
    4680000 = 10001110110100101000000
    1000111-0110100101000000
    Upper part = 1000111 = 71 decimal
    Display = 0.071
    13 / 182.04166666666666666666666666667
    = 0.071412222476539253833829251544976
    About precision
    Example with earth's longitude:
    A degree of longitude at the equator is 111.2 kilometers
    a minute is 1853 meters and a second is 30.9 meters.
    Convert degrees to decimal degrees:
    Example 09°59'58" (9 degrees, 59 minutes, 58 seconds).
    = Decimal degrees 9.9994
    Example 09°59'57" (9 degrees, 59 minutes, 57 seconds).
    = Decimal degrees 9.9991
    Example 09°59'56" (9 degrees, 59 minutes, 56 seconds).
    = Decimal degrees 9.9988
    Convert decimal degrees to degrees:
    9.999 > 09°59'56"
    9.998 > 09°59'52"
    9.997 > 09°59'49"
    Above conversions done with:
    http://www.beg.utexas.edu/GIS/tools/DMS_DD.htm
    http://www.beg.utexas.edu/GIS/tools/dd_dms.htm
    Best regards,
    Luciano
    Default Thanks
    Thank you All ,
    I will have a look and give it a try this weekend, but both Ingvar and Luciano
    pointed me in the direction
    I only need to check the SERIN2 command to see how to handle the incomming string in my previous msg
    Precision is 2 decimals
    The project is to read out 2 position absolute encoders
    which are polled by a controller over a RS485 line at 9600bd
    Thanks again to everyone who helped me
    Walter
    Post
    Ok, since you only need 2 decimals and my code gives 3 you can use the extra precision to round the result .......
    FracPartOfPos1 = (FracPartOfPos1 + 5) / 10
    LCDOUT DEC3 IntPartOfPos1, ".", DEC2 FracPartOfPos1
    ..... should give you a correctly rounded result with 2 decimals.
    /Ingvar
    Default Serin2 help
    Hmm looks that I'm doing something wrong
    I receive serial at 9600 bd N8,1 the following in hex
    example:
    21 AD 34 01 22 EF 23 02
    loop:
    AZ var word
    EL var Word
    Serin2 portb.2,84,[wait ("!"),AZ] => "!" is the ascii represenataion of 21 hex
    would like to store AD 34 in variable AZ, 01 dont care
    then the same for EF 23 in EL
    Use an SP485 RS485 driver in front
    Italy
    Your example data:
    ' The code (Not tested)
    my_array VAR BYTE[7] ' Define array variable with 7 locations
    SERIN2 IN_PIN, BAUD,[WAIT("!") STR my_array\7]
    ' Waits for the string "!", then collects the next 7 characters.
    ' (21 HEX = ASCII !)
    This could be valid data:
    21 21 21 01 22 21 21 02
    Make sure you verify that "01" "22" "02" are in the
    right position in the array.
    From PicBasic manual:
    An optional Timeout and Label may be included to allow the program
    to continue if a character is not received within a certain amount of time.
    Timeout is specified in 1 millisecond units. If the serial input pin stays in
    the idle state during the Timeout time, the program will exit the SERIN2
    command and jump to Label.
    PicBasic Pro Code that demonstrates the use of modifiers
    with the Serin2 and Serout2 commands.
    http://www.microengineeringlabs.com/...bp/ser2mod.bas
    Luciano
    Default Thanks
    Everything is working
    I would like to thank those who post some replys
    If someone is in the Belgian Area, I will certainly offer a Beer
    Walter
  1. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 18:21
