Which EEPROM is suitable for interfacing with PIC16F877A
Results 1 to 5 of 5
    Default Re: Which EEPROM is suitable for interfacing with PIC16F877A
    I'm using the SST25 series of SPI memory devices, technically it's FLASH and not EEPROM but I don't think it matters. A 512kBit (64kByte) device costs around 60 cents. Since it's SPI you can use SHIFTOUT/SHIFTIN or you can use the MSSP module of the '877 for increased performance. These are not 5V devices though.
    I'm sure though that "any" device will work just fine.
    I like the I2C external EEPROMs like the 24AA256:
    http://ww1.microchip.com/downloads/e...doc/21203m.pdf
    Find the right serial EEPROM for you:
    http://www.microchip.com/stellent/id...GE&nodeId=2697
    USA - Arizona
    For adding ROM you could look at SPI EEPROMS or SPI FRAM. For adding RAM you could look at SPI RAM.
