4 Wire resistive touch screen, Need help
Results 1 to 17 of 17
    Miami, Florida USA
    Default Re: 4 Wire resistive touch screen, Need help
    Hmmmm , I am trying to post some code but when I go back to the editing window all I see is the following, everything after "TRISA =" is missing.
    START:
    '################ START READING AVERAGE PRESSURE VALUE ################
    TRISA =
    Anonymous
    1. Click on GO ADVANCED at bottom right.
    2. Click on the leftmost icon, it is two A; it will say SWITCH EDITOR TO SOURCE MODE when you mouse over.
    3. Click on the CODE icon at far right in the middle row.
    4. Paste your code within those tags.
    WYSIWYG mode gives unpredictable results when you paste code, always switch to source mode first.
    Miami, Florida USA
    Wow, that fixed it. It was driving me nuts . Thank you.
    Anonymous
    1. Click on SETTINGS at top right.
    2. Click on General Settings at left.
    3. Scroll down to Miscellaneous Options.
    4. Select Standard Editor.
    You will now be in SOURCE mode by default when you post and not have to worry about code.
    Miami, Florida USA
    Well, I tried in a second computer and it didn't work either. Somehow when I copy-paste the code from MCS into the editor window and press the button "Go Advanced" all the code after "TRISA =" is missing in my editor window and the window kind of freezes up. Is this some kind of bug, because I tried it in two different computers? So, I will attach the code as a txt file.
    Megahertz,
    I wrote a program a while back to control a 4-wire touchscreen in a 320x240 color GLCD. The program worked great. I used a PIC18F4550. The wiring that I used was
    PortA.0, AN0 ---> X+
    PortA.1, AN1 ---> X-
    PortA.2, AN2 ---> Y+
    PortA.3, AN4 ---> Y-
    First, you need to "monitor" the touchscreen to find out if it has been touched. Then if it has been touched you find the coordinates for the point were the screen was touched.
    Also, in this program I had a calibration routine. I displayed in the screen two crosses, one at the upper left corner and the other one at the lower right corner. The user had to touch one cross first and then the other cross to save the optimum parameters for the touchscreen.
    The program is attached as a txt file. Review the program and if you have any questions let me know.
    Touchscreen_Code.txt
    Anonymous
    Tadaa!
    '*         MAIN PROGRAM                                         *
    START:
        TRISA = %00001001           ' Set Y+ (portA.2, AN2) and X- (portA.1, AN1) as outputs
                                    ' and Y- (portA.3, AN3) and X+ (portA.0, AN0) as inputs
        low PORTA.1                 ' Set X- = 0V
        high PORTA.2                ' Set Y+ = 5V
        ADCON0 = %00000001          ' Bits(5-2): 0000=AN0. Start sampling at X+
        pauseus 10
        ADCON0.1 = 1                ' Stops or continues sampling depending on ADCON2 bits(5-3),
                                    ' then begins conversion
        GOSUB CONVERSION_ROUTINE    ' Obtain value for A/D conversion resolution
        PRESSURE_XP = RESOLUTION    ' Obtain PRESSURE_XP from X+ sampling, X- = 0V, and Y+ = 5V
        ADCON0 = %00001101          ' Bits(5-2): 0011=AN3. Start sampling at Y-
        pauseus 10
        PRESSURE_YM = RESOLUTION    ' Obtain PRESSURE_YM from Y- sampling, X- = 0V, and Y+ = 5V
        IF (PRESSURE_XP > 24) AND (PRESSURE_YM < 1000) THEN         ' THE TOUCHSCREEN HAVE BEEN TOUCHED
            GOSUB READ_COORDINATES
            gosub CALIBRATE_TOUCHSCREEN
        LCDOUT $FE, 1                                                       ' Clear LCD
        LCDOUT $FE,2,"X=",DEC5 X_VALUE,", Y=",DEC5 Y_VALUE                  ' DISPLAYS A/D CONVERSION VALUES
        LCDOUT $FE,$C0,"P1=",DEC4 PRESSURE_XP,", P2=",DEC4 PRESSURE_YM
        GOTO START
    '*         READ X AND Y VALUES SUBROUTINE                       *
    READ_COORDINATES:
        ' PORTA.0 (AN0) -> X+
        ' PORTA.1 (AN1) -> X-
        ' PORTA.2 (AN2) -> Y+
        ' PORTA.3 (AN3) -> Y-
        '################ READ AVERAGE X-VALUE ################
        TRISA = %00000011                   ' Set X+ (portA.0, AN0) and X- (portA.1, AN1) as inputs
                                            ' and Y+ (portA.2, AN2) and Y- (portA.3, AN3) as outputs
        low PORTA.3                         ' Set Y- = 0V
        pauseus 10
        X_VALUE = RESOLUTION                ' Obtain X_VALUE from X+ sampling, Y- = 0V, and Y+ = 5V
        ADCON0 = %00000101                  ' Bits(5-2): 0001=AN1. Start sampling at X-
        pauseus 10
        X_VALUE = (X_VALUE + RESOLUTION)      ' Obtain X_VALUE from X- sampling, Y- = 0V, and Y+ = 5V
        '################ READ AVERAGE Y-VALUE ################
        TRISA = %00001100                   ' Set X+ (portA.0, AN0) and X- (portA.1, AN1) as outputs
                                            ' and Y+ (portA.2, AN2) and Y- (portA.3, AN3) as inputs
        high PORTA.0                        ' Set X+ = 5V
        ADCON0 = %00001001                  ' Bits(5-2): 0010=AN2. Start sampling at Y+
        pauseus 10
        Y_VALUE = RESOLUTION                ' Obtain Y_VALUE from Y+ sampling, X- = 0V, and X+ = 5V
        pauseus 10
        Y_VALUE = (Y_VALUE + RESOLUTION)      ' Obtain Y_VALUE from Y- sampling, X- = 0V, and X+ = 5V
    '*         CONVERSION SUBROUTINE                                *
    CONVERSION_ROUTINE:
        REPEAT          ' Wait until conversion is finished. When finished ADCON0.1 will be =0
            PAUSEUS 10
            CONV_STATUS = ADCON0.1
        UNTIL CONV_STATUS = 0
        RESOLUTION.BYTE0 = ADRESL : RESOLUTION.BYTE1 = ADRESH       ' READ A/D CONVERSION VALUE
    '*         CALIBRATION SUBROUTINE                               *
    CALIBRATE_TOUCHSCREEN:
        IF X_VALUE < 250 THEN
            X_VALUE = 0
            X_VALUE = (X_VALUE - 250) * 22
        IF Y_VALUE < 250 THEN
            Y_VALUE = 0
            Y_VALUE = (Y_VALUE - 250) * 25
        IF X_VALUE > 32750 THEN X_VALUE = 32750
        IF Y_VALUE > 32750 THEN Y_VALUE = 32750
        X_VALUE = ABS (X_VALUE - 32750)
        'Y_VALUE = ABS (Y_VALUE - 32750)
    Nov 2009
    London
    Thanks a lot. I am sorry for not replying upto now, I just got my touch screen today (4wire), will study the whole code tonight and update the progress in couple of days. Thanks again for the code.
    Nov 2009
    London
    Okkkk, I have read the code and tried to digest it. Few questions:
    1) Can you please explain how is "Start reading average pressure value" routine is working. Upto now I have only encountered putting 5v on y+ or x+ and corresponding y- or x- to be 0v. What is 5v @ y+ and 0v and x- doing?
    2) Any ideas on how to change the circuit to add an interrupt on RA2 when touchscreen is pressed, unlike monitoring it continuesly?
    3) Please explain the calibrate routine, this is the hardest bit of the code which I am failing to understand.
    Many Thanks
    Miami, Florida USA
    I got the theory for this program from a technical paper that I downloaded from the internet and that I can't find right now. I will keep looking for it and posted when I find it. In response to your questions,
    1) The "start reading average pressure value" is a procedure to check if the screen has been touched. You monitor the two values for X and Y pressure and if they go outside a given range then that means that the screen has been touched. If you constantly output these two values to a LCD display you'll see what I mean.
    2) No, that I know of. The method I used in my program to detect if the screen has been touched is the only method I could find in the internet.
    3) I am not in front of my PC right now, and I can't answer that question from the top of my head. I'll get back to you later with this question.
    Anonymous
    Interesting thread.
    About point 2).
    Since it is an analog signal, I cannot see a way of diect interrupt. Only regular interrupts to start analog conversion and check.
    Miami, Florida USA
    Quote Originally Posted by Megahertz View Post
    This application note will help you understand better what is going on.
    http://www.eetasia.com/ARTICLES/2004...URCES=DOWNLOAD
    Before you start reading the touchscreen coordinates, you need to know if the screen has been touched. By having 5V at Y+ and 0V at X- you monitor if the screen was touched. The setup is as follows
    And the code is
    START:
        pauseus 10
        pauseus 10
            gosub CONVERT_TO_PIXELS
        GOTO START
    If the screen is not touched then the reading for PRESSURE_XP is going to be very close to zero and the reading for PRESSURE_YM is going to be very close to 1024, remember it is a 10-bit ADC. The screen has been touched when the following condition has been met
    To read the X,Y coordinates you need the following setup.
    And the code is
    READ_COORDINATES:
        pauseus 10
        pauseus 10
        pauseus 10
        pauseus 10
    CONVERSION_ROUTINE:
            PAUSEUS 10
    For the final routine "CONVERT_TO_PIXELS" the constants Ax, Bx, Ay, and By should be found experimentally. They will vary depending on the resolution of the LCD screen. One thing to remember is that the relation of the 4-wire touchscreen readings and the corresponding LCD pixels behaves almost linearly.
    '*         CONVERT_TO_PIXELS ROUTINE                            *
    CONVERT_TO_PIXELS:
         'Ax, Bx, Ay, and By should be found experimentally
        X_VALUE = Ax * X_VALUE + Bx
        Y_VALUE = Ay * Y_VALUE + By
    Anonymous
    nevermind, read code few more times...
