Can't set portb.0 low
Results 1 to 7 of 7
    Apr 2007
    Pennsylvania, USA
    Default Can't set portb.0 low
    I know this seems really trivial, but I am using an 18F2620 and I set portb.0 high in the beginning of the program with no problems. Later I try to set it low, and it won't go low. The program is quite large, and I can't figure out what could possibly prevent setting the pin low. I have one of my programs from a week earlier, before adding a bunch of stuff, and it works fine proving it is not hardware related.
    I am turning off the AD and comparators for that pin with
    ADCON1 = (%)00001010 (without the brackets)
    CMCON = 7
    TRISB.0=0 'set to output
    PORTB.0=1 'sets the pin high, which works fine
    I have tried:
    LOW portb.0
    PORTB.0=0
    putting a pause before and after setting it low.
    Nothing works. I am sure it is something stupid in my code, but maybe if you can bounce some ideas I will be able to find it. I am using the CCP1 module for measuring pulses on portc.2, as I was on the older program that works fine.
    Shawn
    Default Re: Can't set portb.0 low
    Shawn,
    Have you tried?
    LATB.0 = 0
    Apr 2007
    Pennsylvania, USA
    I have never used that, but will try it this evening. When and why should LAT be used?
    Shawn
    Aug 2008
    Portugal
    Quote Originally Posted by spcw1234 View Post
    When you use 18F series. Because of the RMW issue!!!
    Thanks and Regards;
    Gadelhas
    Apr 2007
    Pennsylvania, USA
    Using LAT did not work. I don't think it is RMW as I am not reading the port, I already know it's state is high, I just want to make it low.
    Thanks for the help!
    Shawn
    Apr 2007
    Pennsylvania, USA
    OK, I got it working, after I commented out the line below it worked. Took me a while to understand why, then I saw it... The gosub wait1 is to wait for the ACK from the LCD display. If no ACK, it reboots the display. Well I jump to a routine that waits for the ACK, then return and wait again without sending another command to the display. Stupid little mistake trying to shrink the program to save some flash space.
    shutdown:
      serout2 tx, baud, ["s", 0, 2, 2, white1, white2, "- GOOD BYE -", $00] : gosub wait1
    ;  gosub ln3blank : gosub wait1  ;PORTB.0 CAN GO LOW WITH THIS LINE COMMENTED OUT??????
      serout2 tx, baud, [$59, $03, $00] : gosub wait1
      PORTB.0=0        'shutdown main power relay  NOT GOING LOW??????????
      pause 5000       'wait for relay to drop out
    goto start  'if processor is still running, then reboot
    ln3blank:
      serout2 tx, baud, ["s", 0, 3, 2, white1, white2, "            ", $00] : gosub wait1
    wait1: 'WAIT FOR ACK FROM DISPLAY
      serin2 rx, baud, 500, initdisp, [a]        'wait 500ms for serin, else goto wait2
      if a<>6 then waitfail '????         'check for ACK, if not then reinitialize display
    Shawn
