Ever had one of those days....
Results 1 to 6 of 6
    Dec 2003
    Wichita KS
    The datasheet does not show a 10MZ internal clock.
    Make sure you have your programmer assigned to external clock, not internal.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Feb 2004
    Michigan, USA
    Im using a 10mhz external ceramic resonator, using the HS fuse.
    Im using version 2.43, there was some kind of fix on the latest versions for the configuration of the 18f1320. Could this be the problem?
    UPDATE:
    Tried the same simple program on a 16f818 and it works as expected. Must be the 18f1320 config error.
  1. Best IDE / Compiler to use these days ???
    By gtvmarty in forum General
    Last Post: - 4th July 2008, 14:31
  2. Two PIC 16F877A fried in two days!
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 11:38
  3. Replies: 5
    Last Post: - 21st August 2006, 00:09
  4. Timer Of 40 Days 12f675 Or 16f628
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 21st August 2005, 01:11
  5. How to learn PIC BASIC compiler in 7 days?
    By luqman83salleh in forum General
    Last Post: - 13th August 2004, 15:15
