I am using the 18f1320. Im setting fuses via the epic programmer just as im about to upload the program to the pic. This error occurs and sometimes i dont even get to epic.
The datasheet does not show a 10MZ internal clock.
Make sure you have your programmer assigned to external clock, not internal.
Dwayne
Ability to Fly:
Pilots that are Flying:
Im using a 10mhz external ceramic resonator, using the HS fuse.
Im using version 2.43, there was some kind of fix on the latest versions for the configuration of the 18f1320. Could this be the problem?
UPDATE:
Tried the same simple program on a 16f818 and it works as expected. Must be the 18f1320 config error.
