1Hz clock using Timer3, 32.768kHz crystal and runs badly on 18F26k22
Results 1 to 16 of 16
    Nov 2008
    Default Re: 1Hz clock using Timer3, 32.768kHz crystal and runs badly on 18F26k22
    Hi Chris
    I had this problem on a 24k22, turned out to be the TxRD16 bit of TxCON being set for 16bit mode. Changing this to 8 bit mode solved it for me.
    Quote Originally Posted by BH_epuk View Post
    Hi Chris
    Hi, thanks for that.
    I did get around to suspecting that and tried changing between 16-bit and 8-bit modes but there was no difference - and I couldn't explain how it would make a difference because the 25k22 and 26k22, which use identical registers.
    The only difference between the two timers seems to be that they use different interrupt registers, not between devices though, so I still can't quite explain how the fault occurs
    Alabama,USA
    Chris,
    I am trying to make the leap from 16F’ to 18F’s. I want to start with the 18F25k22. Would you mind sharing some 25k22 code? I would be interested in what your config’s look like for your 25k22 clock project?
    Thanks!
    Wayne
    Hello Wayne,
    there is probably little point in using my configs, unless yoiu plan to set up your pic to mimic mine.
    Your best way top approach it is to decide which peripherals you would like to use first of all, and then look in the MPASM directory for the 18F25k22.inc file. At the end of that file all of the correct mnemonics for the configs are listed.
    I generally copy the ones I want to use from the Microchip include file and put them in the Picbasic 18f25k22.inc include file to enable them.
    Chris
    Just a reminder that this has changed in PBP3, if that's what you have. There's no longer any need to edit .inc files etc, instead use #CONFIG/#ENDCONFIG to override the defaults. Also take a look a the DEVICE_REFERENCE folder of the PBP install folder, there you'll find a .INFO file for each supported PIC outlining the available configs etc. The .INFO is just a plain text file so you can open it Notepad or MCSP or whatever.
    For example, here a config block for the 18F25K22 on a project of mine (requires PBP3)
        CONFIG FOSC = HSMP
        CONFIG PLLCFG = ON
        CONFIG PBADEN = OFF
        CONFIG MCLRE = EXTMCLR
        CONFIG LVP = OFF
        CONFIG XINST = OFF
    Obviously this doesn't contain ALL the CONFIGs - just the ones I was currently interested in. Again, very easy and flexible, no need to edit files etc.
    Alabama,USA
    Thank you Chris and Henrik for your comments.
    I am using MCSP, PBP 2.60c, and MPLAB8.83. When I compile from MCSP I get a statement “18F25K22.INC not found”, in addition to other errors. In PBP I have three files for 18F25K22. 18F25K22.INC, 18F25K22.Visual Basic Module, 18F25K22.BAL are in C:\PBP.
    There is NO M18F25K22.INC in C:\PBP\INC.
    If I understand what you are saying, I should copy the P18F25K22.INC from C:\Microchip\MPASM Suite into PBP\INC. Is that correct? If so, should I call it M18F25K22?
    I also find in C:\Mecanique\MPASM has INC files. There is NO P18F25K22 in this folder. Should there also be a P18F25K22 file in this folder?
    Thank you for your help. I’ve been working with this for several days, reloaded all my programs and updating from PBP2.60, 2.60a, 2.60c. My forehead feels like mister-e’s after banging the keyboard for hours!
    Wayne
    There should be a 18F25K22.INC, a 18F25K22.BAS and a 18F25K22.BAL file in the PBP folder and there should be a P18F25K22.INC in the MPASMSuite folder. If you need to EDIT the configs (for PBP versions PRIOR to 3.0) the file you should edit is the 18F25K22.INC in the PBP folder. You should not copy and or rename any files.
    My 18F25K22.INC file in C:\PBP looks like this (this is for v2.6):
    ;*  18F25K22.INC                                                *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2010 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 05/11/10                                        *
    ;*  Version   : 2.60a                                           *
    ;*  Notes     :                                                 *
    ;Edited 2011-03-02 //Henrik
    ;Commented out configs in order to set in code
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F25K22, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F25K22.INC" ; MPASM  Header
    ;        __CONFIG    _CONFIG1H, _FOSC_INTIO67_1H
    ;        __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
    ;        __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
            NOLIST
            LIST
    EEPROM_START EQU 0F00000h
    BLOCK_SIZE EQU 64
    As you can see I've commented the default __CONFIG lines here so that I could have them in my program instead. You can do that OR edit the the file to match your needs but DO back it up before changing.
    I don't know why it says it can't find your 18F25K22.INC if it's there. If you happen to have multiple versions of the compiler make sure you're executing the correct one. Also make sure that MCS is indeed pointing to the correct MPASMSuite folder (if you have multiple versions installed), it's usually something like C:\Program Files\Microchip\MPASMSuite\
