Shiftout command
Results 1 to 5 of 5
    Jun 2011
    Indian Harbour Nova Scotia
    Default Re: Shiftout command
    So why, if the PIC is driving the clock does the Shiftout command even need that parameter? Is the port associated with it (in your example PortB.2 or PortD.0) just a "holding place" for it or is the port connected inside the PIC itself? If I scoped one of those ports would I see a clock signal? (i'm going to try it...)
    Also, how can a constant be used for ClockPin with a value of 0-15? How does THAT work?
    SHIFTOUT/SHIFTIN are used for synchronous communications (unlike SEROUT/SERIN etc which are asyncrounous) which means that there one dataline and one clock line (and quite often a chip select). If you SHIFTOUT a byte variable there will be 8 pulses on the pin you specify as ClockPin. During each pulse the 8 indivdual bits of your byte variable will be present as a voltage on the DataPin. Depending on the MODE you specify with the SHIFTOUT command you can change the exact behaviour of the output ie. in which order the bits are shifted out and the "polarity" of the clock.
    Please do scope it and you'll see how it works.
    EDIT: Oh, the constant thing. That's just to be compatible with the BasicStamp2 syntax where the I/O's are labeled 0-15. Usually '0' is PortB.0 but it might differ depending on the actual PIC you're compiling for. Best is to just forget about that and use PortB.3 etc.
    Jun 2011
    Thanks Henrik. That does clear somestuff up. I put a logic probe on the pins and sure enough they do what you say they do. I was making it more complicated than it actually was. I do have the portion running with the Shiftout command, looks so SIMPLE now!
    BTW Congratulations Sweden on beating the Russians and winning GOLD in the Junior World Hockey championship.
