LCDOUT bits
Results 1 to 3 of 3
Thread: LCDOUT bits
    Dec 2011
    IO93ok
    Default LCDOUT bits
    Hi all,
    The large character routine worked so well I wanted to try this on an existing project that has a two line display.
    However the wiring of the display is non standard as the code was implemented by someone else using asm. I am unable to change the wiring.
    I'm re-writing the original code operation to suit myself in PBP.
    Is it possible to use defines as :-
    DEFINE LCD_Bit4 PORTB.4
    DEFINE LCD_Bit5 PORTB.5
    DEFINE LCD_Bit6 PORTB.2 ---- ;NOTE THIS ONE
    DEFINE LCD_Bit7 PORTB.7
    Dec 2011
    IO93ok
    Default Re: LCDOUT bits
    Ahhh, many thanks for that.
    I did a search but that didn't come up.
