Darrel Taylor Interrupts and MultiCalc
Results 1 to 7 of 7
    Sep 2010
    Las Vegas, NV
    Default Darrel Taylor Interrupts and MultiCalc
    Well, I'm trying to make a clock and I am trying to get exactly 100 pulses to use Darrell Taylors Instant Interrupt program. Which is pretty darn good by the way and I'm really a rookie.
    Anyway, I have a 16F877A with a LED on Portb.1 that is supposed to blink at 100 hz. There is another LED on Portd.0. Other than those two LEDs, nothing else, other than power, is hooked up to the 16F877A. I'm looking at the LED on portb.1 pulses with an Oscope and I found that without preloading the timer it ran at about 950mHz. So, on a different post, I found the preload needed to get to 100 hz and with a little tweaking I get 100 hz. The issue I have is to get that 100 hz the preload numbers used I had to tell Multicalc I wanted to run the system at 200 hz in the Interrupt/Frequency window. What am I missing here?
    Secondly, what is the Reload window for and how do you use it?
    Please refer to the part where I said I was a rookie and be gentle. I've attached my code for even more scrutiny.
    [CODE];This program will blink a light on portb.1 at a 1 hz rate --
    'with another LED on portd.1 blinking at a different rate
    'different TMR1 preloads to get desired frequencies
    wsave VAR BYTE $70 SYSTEM ' alternate save location for W
    wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1
    wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2
    wsave3 VAR BYTE $1A0 SYSTEM ' location for W if in bank3
    LED1 VAR PORTB.1
    led2 VAR portd.0
    INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts
    DEFINE osc20
    INT_Handler TMR1_INT, _ToggleLED1, PBP, yes
    T1CON =
    Default Re: Darrel Taylor Interrupts and MultiCalc
    Make sure to have your post window in SOURCE MODE so your CODE blocks don't get ruined.
    Click the leftmost icon above your post window; SWITCH EDITOR TO SOURCE MODE. Then go to advanced mode (below post window at right) to get the CODE icon.
    Sep 2010
    Las Vegas, NV
    Well, it's refreshing to learn something new. Anyway, here's the code that didn't come through earlier.
    LED1   VAR  PORTB.1
    led2   VAR portd.0
    DEFINE osc20
    T1CON = %00000001                ; Prescaler = 1:1, TMR1ON
    preload VAR WORD
    preload = 61476 '60543 by MultiCalc should yields about 200Hz but
                    '60643 yeilds exactly 100 Hz
                    ' 48876 29.8cps
                    ' 57209 yields 59.5cps
                    ' 61376 yields
    tmr1l = preload.LowByte
    tmr1h = preload.HighByte
      PAUSE 500
      TOGGLE led2
      PAUSE 500
      TOGGLE led2
    GOTO Main
    '---[TMR1 - interrupt handler]------------------------------------
    ToggleLED1:
               t1con.0 = 0
               t1con.0 = 1
         TOGGLE LED1
    @ INT_RETURN
    I'm pretty sure PAUSE messes up the timer routines.
    I think you're supposed to use FOR loops instead.
    EDIT: Something like:
    for loop = 1 to 500
        pause 1
    next loop
    He's not using ON INTERRUPT Robert.
    Greg,
    It takes 2 interrupts to turn an LED On and Off. So 200hz interrupts produces a 100 hz flashing led.
    If you want to keep time from 100hz interrupts, that would be too fast.
    Since you want accuracy, you shouldn't just load the timer with a value.
    It takes time to get to the interrupt handler, and the timer has been counting during that time.
    If you just load a value into the timer, that amount of time is lost.
    If you ADD the reload value to the current timer value, it no longer matters how long it took to get to the handler.
    It also takes a certain amount of time to ADD the value to the time, and that time must be accounted for as well.
    Take a stab at the "Timer Template" http://www.darreltaylor.com/DT_INTS-...rTemplate.html
    It does all that stuff for you.
    Use a prescaler of 1.
    It should give exactly 100hz interrupts, down to the exact cpu cycle.
    Close enough to be only a few seconds off after a month or two. Depending on your crystal.
    Sep 2010
    Las Vegas, NV
    Thank you. It's always nice getting a concise answer to a question. Especially when it is understandable and works.
    Now if I could learn to be more concise asking the questions.
    Regards.
    Sometimes, it's only after you've gone through the pain, that an answer makes sense.
    Thanks for the original effort.
