Can't Toggle PORTC.4 on PIC18F13K22
Results 1 to 5 of 5
    Default Re: Can't Toggle PORTC.4 on PIC18F13K22
    Try it with ...
    CONFIG XINST = OFF
    CONFIG LVP = OFF
    Feb 2010
    USA, New England
    Wow, thanks Darrel! How come that made it work?
    On that chip, RC3 is also the PGM pin for Low Voltage Programming (LVP).
    When LVP is enabled, you can't use that pin for anything else.
    And you should ALWAYS disable the Extended Instruction Set (XINST).
    PBP will not function properly when XINST is enabled.
    Feb 2010
    USA, New England
    Thank you for taking the time to explain, it is much appreciated.
    Best Regards,
    Paul
