Can't Toggle PORTC.4 on PIC18F13K22
Results 1 to 5 of 5
    Feb 2010
    USA, New England
    Default Can't Toggle PORTC.4 on PIC18F13K22
    I'm working my way around a new PIC, the 18F13K22 at a smokin' 64 MHz using the internal osc and PLL. Finally got that working but for the life of me, I can't get pin 7 (RC3) to toggle. The following code toggles pin 8 (RC4) but not pin 7:
    #config    CONFIG FOSC = IRC        ;Internal RC oscillator
        CONFIG PLLEN = ON        ;Oscillator multiplied by 4
        CONFIG IESO = OFF        ;Oscillator Switchover mode disabled
        CONFIG BOREN = OFF        ;Brown-out Reset disabled in hardware and software
        CONFIG WDTEN = OFF        ;WDT is controlled by SWDTEN bit of the WDTCON register
        CONFIG WDTPS = 32768        ;1:32768
        CONFIG MCLRE = ON        ;MCLR pin enabled, RA3 input pin disabled
        CONFIG XINST = ON        ;Instruction set extension and Indexed Addressing mode enabled
    DEFINE OSC 64
    ANSEL = 0
    ANSELH = 0
    LATC  = %11000100
    TRISC = %00000000
    LATB  = %01000000
    TRISB = %00110000
    LATA  = %00000000
    TRISA = %00000111
    'Set internal osc to 16 MHz, PLL enabled
    OSCCON.6 = 1
    OSCCON.5 = 1
    OSCCON.4 = 1
    OSCTUNE.6 = %1
        LATC.4 = 1
        LATC.3 = 1
        LATC.4 = 0
        LATC.3 = 0
    goto Main
    Am I missing something silly and obvious?
    Best Regards,
    Paul
    Default Re: Can't Toggle PORTC.4 on PIC18F13K22
    Try it with ...
    CONFIG XINST = OFF
    CONFIG LVP = OFF
    Feb 2010
    USA, New England
    Wow, thanks Darrel! How come that made it work?
    On that chip, RC3 is also the PGM pin for Low Voltage Programming (LVP).
    When LVP is enabled, you can't use that pin for anything else.
    And you should ALWAYS disable the Extended Instruction Set (XINST).
    PBP will not function properly when XINST is enabled.
    Feb 2010
    USA, New England
    Thank you for taking the time to explain, it is much appreciated.
    Best Regards,
    Paul
