Interrupts and Disable 16f877
Results 1 to 6 of 6
    Mar 2004
    Default Interrupts and Disable 16f877
    I'm trying to learn how to use interrupts and in all the examples I find the word DISABLE appears.
    But to me it doesn't appear to do anything as it is never passed by the program.
    Am I being thick?
    My next question is the 16f877 shows it has 14 Interrupts but the paper work only shows interrupts on some of the RB pins?
    And lastly I want to use four different RBx pins to trigger four different bits of code. But looking at example and reading the paperwork I can not see how I differentiate between which pins causes the interrupt as once enabled any of the RB pins cause an interrupt? or do I have to do this in code?
    I'm sure this is obvious to everyone except me but I've spent all weekend reading and can not see the wood for the trees.
    Rob
    ***EXAMPLE*****
    ' On Interrupt - Interrupts in BASIC
    ' Turn LED on. Interrupt on PORTB.0 (INTE) turns LED off.
    ' Program waits .5 seconds and turns LED back on.
    led var PORTB.7
    OPTION_REG = $7f ' Enable PORTB pullups
    On Interrupt Goto myint ' Define interrupt handler
    INTCON = $90 ' Enable INTE interrupt
    loop: High led ' Turn LED on
    Goto loop ' Do it forever
    ' Interrupt handler
    Disable ' No interrupts past this point
    myint: Low led ' If we get here, turn LED off
    Pause 500 ' Wait .5 seconds
    INTCON.1 = 0 ' Clear interrupt flag
    Resume ' Return to main program
    Enable
    Italy
    Hi!
    I've spent all weekend reading....
    (>400 pages)
    http://www.mind-tek.com/assets/images/speed.JPG
    Q1. DISABLE
    See PicBasic Pro manual.
    DISABLE and ENABLE are pseudo-ops in that they give the compiler
    directions, rather than actually generate code.
    Q2. 14/15 interrupts.
    Open the data sheet of the 16f877 and search the word 'interrupt'.
    Read section 8 of the Mid-Range MCU Family Reference Manual.
    http://ww1.microchip.com/downloads/e...Doc/33023a.pdf
    Q3. PORTB Interrupt.
    AN566 - Using the PORTB Interrupt on Change as an External Interrupt.
    http://ww1.microchip.com/downloads/e...tes/00566b.pdf
    Best regards,
    Luciano
    Mar 2004
    Luciano
    The data sheet you pointed to is different to mine so perhaps that's the first lesson I have learnt. The one I downloaded covers several 16f8xx and only had a couple of lines about interrupts but was over 200 pages long.
    Secondly I have misplaced my PBP manual and I'm using the online HTML version which is not ideal.
    Thank's for taking the time to reply it is very much appreciated.
    Rob
    Italy
    Rob
    The datasheets are only one part of the documentation.
    See http://www.microchip.com for:
    - Reference Manuals
    - Datasheets
    - Application Notes
    - (and more)
    PicBasic Pro manual in PDF format.
    http://www.melabs.com/downloads/pbpm304.pdf
    PIC16F873/4/6/7 Datasheet
    http://ww1.microchip.com/downloads/e...Doc/30292c.pdf
    PIC16F87XA Datasheet (Parts with an "A" suffix).
    http://ww1.microchip.com/downloads/e...Doc/39582b.pdf
    PIC16F87XA Rev. B2 Silicon/Data Sheet Errata
    http://ww1.microchip.com/downloads/e...Doc/80133f.pdf
    Luciano
    Mar 2004
    Luciano
    I'm still not having any luck making my interrupts work, they appear to be permanently on but looking over my circuit I may have found my problem and would appreciate another opinion.
    I use RB0,1,2 as outputs to drive another chip serially so I am assuming I can use these as outputs and still use RB4:7 as inputs?
    My code goes like this (I have just cut n pasted the interrupt bits)
    When I scope RB4 it always appears to be at a low level where as RB5:7 are just under 5 Volts? When you use the internal pull-ups I assume volts appear on the appropriate pin? Or am I dragging down RB4 where it's connected to another IC, and this is causing a permanent interrupt?
    I have one of the Lab -x3 * x2 boards and was trying to get a working interrupt demo on a 16f628 but I still had no joy.
    Sorry to be a pain but all pointers gratefully accepted.
    Rob
    OPTION_REG = %1111000 ' Enable PORTB pullups
    INTCON = %10011000 ' Enable INTE interrupt
    On Interrupt Goto NoVideo ' Define interrupt handler
    disable
    :NoVideo
    IF PORTB.4 = 1 then
    low PORTC.0 'Green LED (bipolar LED)
    high PORTC.1 'Green LED
    IF PORTB.4 = 0 then
    low PORTC.1 'Red LED
    high PORTC.0 'Red LED
    NoSync = PORTB.4
    '**Interrupts stuff
    Enable
    Italy
    Hi!
    Each of the PORTB pins has a weak internal pull-up
    (≈200 µA typical). A single control bit can turn on all the
    pull-ups. This is done by clearing the RBPU
    (OPTION<7>) bit. The weak pull-up is automatically
    turned off when the port pin is configured as an output.
    The pull-ups are disabled on Power-on Reset.
    OPTION_REG.7 = 0 ' Enable all PORTB pullups
    OPTION_REG.7 = 1 ' Disable all PORTB pullups
    To set a pin or port to an output (or input), set its TRIS register.
    Setting a TRIS bit to 0 makes its corresponding port pin an output.
    Setting a TRIS bit to 1 makes its corresponding port pin an input.
    Examples on PORTB:
    TRISB = %11111111 'sets all the PORTB pins to inputs.
    TRISB = %00000000 'sets all the PORTB pins to outputs.
    TRISB = %11110000 'b7,b6,b5,b4=inputs / b3,b2,b1,b0 =outputs
    TRISB = %11100000 'b7,b6,b5=inputs / b4,b3,b2,b1,b0 =outputs
    Try to find out what happen if you set all the PINs of PORTB
    as inputs with TRISB = %11111111 then enable all PORTB pullups
    with OPTION_REG.7 = 0 and then you set TRISB = %11100000.
    ('b7,b6,b5=inputs / b4,b3,b2,b1,b0 =outputs).
    Pullups still there on b7,b6,b5? (Source +5 Volts ≈200 µA).
    External interrupt on RB0/INT pin
    External interrupt on RB0/INT pin is edge triggered:
    either rising if INTEDG bit (OPTION<6>) is set, or
    falling, if INTEDG bit is clear. When a valid edge
    appears on the RB0/INT pin, the INTF bit
    (INTCON<1>) is set. This interrupt can be disabled by
    clearing the INTE control bit (INTCON<4>). The INTF
    bit must be cleared in software in the interrupt service
    routine before re-enabling this interrupt. The RB0/INT
    interrupt can wake-up the processor from SLEEP, if the
    INTE bit was set prior to going into SLEEP. The status
    of the GIE bit decides whether or not the processor
    branches to the interrupt vector following wake-up.
    OPTION_REG.6 = 0 'Interrupt on falling edge of RB0/INT pin
    OPTION_REG.6 = 1 'Interrupt on rising edge of RB0/INT pin
    INTCON = %10010000 'Enable INTE
    INTCON.1 = 0 'Clear RB0/INT External Interrupt Flag bit
    RB<7:4>, have an interrupt-onchange feature.
    Four of PORTB’s pins, RB<7:4>, have an interrupt-onchange
    feature. Only pins configured as inputs can
    cause this interrupt to occur (i.e., any RB<7:4> pin configured
    as an output is excluded from the interrupt-onchange
    comparison). The input pins (of RB7:RB4) are
    compared with the old value latched on the last read of
    PORTB. The “mismatch” outputs of RB7:RB4 are
    OR’ed together to generate the RBIF interrupt (flag
    latched in INTCON<0>).
    INTCON = %10001000 'Enable RBIE
    INTCON.0 = 0 'Clear Port Change Interrupt Flag bit
    From your code:
    (Comment wrong, you enable INTE and also RBIE).
    (Clear RB0/INT External Interrupt Flag bit).
    Best regards,
    Luciano
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 06:10
  3. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
  4. Enable and Disable in Interrupts
    By stevecrunch in forum mel PIC BASIC Pro
    Last Post: - 30th October 2007, 01:10
  5. too many interrupts
    By trying in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2006, 13:38
