LCD not working with 18F4550
Results 1 to 9 of 9
    Default Re: LCD not working with 18F4550
    Hi Robert,
    Analog functions on PortE perhaps?
    Also, you say that you have a 20Mhz x-tal but then you DEFINE OSC 48, is that correct? I know the oscillator on the USB devices are a bit different and I'm not saying you've got it wrong but since it doesn't work perhaps it's worth looking into. Do a simple blink-a-led with a PAUSE 500 or whatever and verify that the timing looks OK.
    Apr 2007
    Pennsylvania, USA
    You may need to initialize the display by sending a clear screen command, then pause 500ms or more before trying to write to it. I have had better luck with the displays doing this. Would also be worth checking the heart beat to verify osc settings like Henrik mentioned.
    Shawn
    Hi Henrik,
    Tried ADCON1=7 with no success.
    That's the way Darrel does it in his DT HID260 example.
    That was the first thing I did with this chip when I couldn't get the LCD working.
    The LCD works fine, I used it for the Lab X1 examples I just added in Code Examples. I can get LEDs to blink back and forth, so I know the PIC can be programmed properly, but that's about it.
    Quote Originally Posted by spcw1234 View Post
    Tried, still nothing on LCD.
    Current code:
    __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
    __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _VREGEN_ON_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H
    __CONFIG _CONFIG3H, _CCP2MX_OFF_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 48
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    ADCON1 = 7
    TRISD = 0
    TRISE = 0
    WSLOOP var byte ' Loop counter
    PAUSE 1000
    LCDOUT $FE,1
    PAUSE 2000
    LCDOUT $FE,1,"LabX1 18F4550"
    PORTD = %00000001 ' Turn 1st LED on
    pause 100 ' Short delay
    CYCLE:
    for wsloop = 1 to 7 ' Turn on next LED from right to left
    PORTD = PORTD << 1
    next
    for wsloop = 1 to 7 ' Turn on next LED from left to right
    PORTD = PORTD >> 1
    next
    GOTO CYCLE
    The LEDs blink back and forth but still no love from the LCD.
    Try 15. 7 only takes care of 8-12.
    DATA sheets are your friend.
    Please read the chips DATA sheet and make it happy
    GAAAAAAAAAAAA!!!!!
    That was it! You have no idea how much of that datasheet I went through, but I missed that part about ADCON1 being different. If it's one thing I learned from Steve, it's RTFM.
    Thanks!
    Aug 2007
    try ADCON1 = %00001111
    Aug 2007
    sorry and LCDOUT $fe,$80,"LabX1 18F4550"
    Quote Originally Posted by selim View Post
    try ADCON1 = 001111
    He did and it fixed it. Did you not see that post?
