RCTIME not getting a result
Results 1 to 3 of 3
    Dec 2011
    IO93ok
    Default RCTIME not getting a result
    I decided to make another 'chicken door' again this time using a 16f84. As it has no ADC for the LDR I tried using RCTIME but all I get is either 0 or 1 as the result, is it my code?
    I tried putting one end of the LDR to 5v the other to a .1 cap which then goes to the pin.
    I tried LDR to pin , other end to cap to ground.
    Both give same result.
    I'm using:-
    LOW PortB.0
    PAUSE 10
    RCTIME PortB.0,0,LDR
    LCDOUT $FE,$80,LDR
    Dec 2011
    IO93ok
    Default Re: RCTIME not getting a result
    OK, no-one answered my simple question.
    Fortunately a YouTube video answered it although it's in Hungarian I think.
    The PBP manual doesn't make it very clear but the video shows that two pins are necessary to use RCTIME ?
    One to charge up the cap the other to measure the discharge.
    One via a 1k resistor the other via a 1Meg resistor and .1 capacitor.
    No, only one pin is used
    '        CAP        POT
    ' +5------||---;---/\/\------ZERO
    ' PIN-----/\/\--'
    '         10K
    But you probably will not be happy with the results. Use a MCU with ADC.
