Toggle command question
Results 1 to 4 of 4
    Default Re: Toggle command question
    Moved from Code Examples.
    Dec 2010
    Looks like it should work.... have you remembered to disable the watchdog timer and anything else that could cause an unscheduled reset?
    trise = %11111110 ' sets bit0 of trise as output - only has 3 ports on trise
    Like your comment said, PORTE only has 3 pins in that PORT.
    By setting the upper bits of TRISE to all 1's, you have turned on the "Parallel Slave Port" (PSP) which affects PORTD.
