Getting 18F458 to blink
Results 1 to 6 of 6
    Feb 2008
    Default Getting 18F458 to blink
    Hey fellow PICers
    After a few projects with PIC 16F series, I try to move on to the more advanced PIC 18F series. But already at the very beginning I got stuck. I tried already to solve it for days, but I have no more clue…
    The hardware setup: PIC 18F458, 20Mhz Xtal on pins OSC1 and OSC2, two 15p caps for the Xtal, an LED with resistor on PORTD.2 (pin 21)
    The program:
    define OSC 20                ' Quarz = 20 MHz
    clear
    ADCON1 = 15 ' all digital
    LED        var    portd.2
    RxTx       var    portc.5
    RS485Rx    var    portc.7
    RS485Tx    var    portc.6
    loop:
       toggle led
       low led
    goto loop
    I had to change the __CONFIG lines in the .inc file in order to work with MPLAB like this:
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F458, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F458.INC"   ; MPASM  Header
            ;__CONFIG    _CONFIG1H, _OSCS_OFF_1H & _HS_OSC
            ;__CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
            ;__CONFIG    _CONFIG4L, _LVP_OFF_4L
        CONFIG OSCS=OFF,OSC=HS,WDT=ON,WDTPS=128,LVP=OFF
            NOLIST
            LIST
    EEPROM_START    EQU    0F00000h
    BLOCK_SIZE    EQU    8
    It compiles and burns into the PIC with no errors.
    What happens when I turn on power is that the LED is always lit. No blinkin’, nothin’
    How can I check if the Xtal works? Or any other hints what to do anyone?
    Thanx & keep on PICin’
    Helloo
    Apr 2007
    Pennsylvania, USA
    Default Re: Getting 18F458 to blink
    Try adding CMCON=7 to your code to disable the comparator
    EDIT: ADCON1=6 would be all digital, ADCON1=15 makes AN0 analog with AN3 VREF+ and AN2 VREF-
    Shawn
    And you can remove LOW LED at the bottom. Toggle will change the state for you; if it was ON, it will turn OFF, and vice versa.
    Do you really need the watchdog timer?
    Can you put the CONFIG statement in the include like that?
    (never saw that before, usually it's at the top of your program, but I don't use MPLAB).
    Aug 2010
    Maryland, USA
    It may be working just perfect. In your loop the first thing you do is toggle the led. Then you pause for half a second. Then you set the output low and instantly go back to the top of the loop, where you will toggle again turning on the led. As was suggested, remove the low led command. Or you could add another pause after it so you will have time to see it go low.
    -Bert
    Feb 2008
    All three of you where right. Thank you all. Deleted the "LED low" command (wich I added after nothing happened). Added "CMCON = 7" as Shawn suggested. Now it works. Grrrmmm three lousy bits, many days no sleep...
    @Demon: Both ways work. But if the CONFIG is in the include file, it mustn't be in the program and vice versa.
    Until PBP 3 that is the default way, configs in the *.inc
    MPLAB has nothing to do with it.
