Classic
Results 1 to 3 of 3
Thread: Classic
    Haggar's Avatar
    Haggar Guest
    Red face Classic
    well my program compiled smoothly but it didnt work as I expected.. here it is .. "btw iam a newbie .. and this is my first atempt to use the thing" ..
    Define loader_used 1
    include "modedefs.bas" 'include serout defines
    clear
    init:
    TRISB=%00000000 'all ports B output
    TRISA=%11111111 'all ports A input
    TXEN var PORTB.0
    PWRUP var PORTB.1
    TXP var PORTB.2
    RXP var PORTA.0 <--- here is the pin where I recieve the serial data from
    LED var portb.3
    EYEMOD1 var Byte
    RXDATA var byte
    TXDATA VAR BYTE
    CHILD1 var byte
    num var Byte
    PORTB=%00000000
    EYEMOD1=%10110100
    CHILD1=%00000011
    RXDATA=%00000000
    Receive:
    High PWRUP
    LOW TXEN
    Pause 3
    Serin RXP,T9600,1000,Standby,["A"],RXDATA <<--- iam suspecting this
    if RXDATA=EYEMOD1 then
    goto transmit
    LOw PWRUP
    PAUSE 2000
    goto Receive
    Standby:
    Low TXEN
    Low PWRUP
    Low led
    pause 5000
    goto Receive
    Transmit:
    High PWRUP
    HIGH TXEN
    pause 3
    TXDATA=RXDATA | CHILD1
    Serout TXP,T9600, ["A",TXDATA]
    PAUSE 1000
    goto Standby
    Could thousands things here
    BUT...
    what about your pic #. More than often, there's analog pins on PORTA (ADC or Comparator). If so, you must disable, at least, this/those lasts on your PIC Serial Data Input.
    Haggar's Avatar
    Haggar Guest
    PIC16F877 .. this is the one ..
    I have two of them communicating with each other using serin/serout the out put of the sending chip was varified to be as "A" + 10110100 using the Oscilloscope.
  1. Old classic If-Then...
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 08:46
