I am using An0 with a 4-20mA input and 1 volt on Vref- to get full 10 bit resolution. I have a 250 ohm resistor and a .1uF cap on An0 to ground. The problem is when the input voltage reaches 2.989 then my raw ADC reading stops at 511 and doesn't change till voltage reaches 3.156 at which time it jumps to 554. When I clear bit 5 of ADCON1 (Vref = Vss) then it works fine with no missing steps, only less resolution.I'm using a 18F4620 uC32MHz internal oscillator OSCCON = %01110000 ' configure 8Mhz OSCTUNE.6 = 1 ' turn on PLLEN ((4 times multiplier (8x4 for 32Mhz)) DEFINE OSC 32 ' Program to use 32Mhz clock TRISA = %11111111 ' all inputs CMCON = %00000111 ' Turn off comparators'--------- F con $FE ' funtion code for LCD Clr con $01 ' Clr LCD print on line 1 Ln1 con $80 ' line 1 on LCD Ln2 con $C0 ' line 2 on LCD Ln3 con $94 ' line 3 on LCD Ln4 con $D4 ' line 4 on LCDDisp: ADCON0 = %00000001 ' A/D module enabled, channel 0 ADCON1 = %00101100 ' Vref = Vdd & 1V ref, AN0 = analog ADCON2 = %10101111 ' Right justified, 12 Tad, Frc clock INTCON = %01000000 ' Global ints disabled, enable peripheral interrupts PIE1.6=1 ' A/D interrupt enabled (for wake from sleep) ADCON0.1=1 ' Start the A/D conversion @ SLEEP ' Sleep until A/D conversion finished WHILE ADCON0.1 ' A/D complete? WEND ' PIR1.6=0 ' Clear A/D int flag ASM ; Put upper and lower byte of A/D in ADResult MOVFF ADRESL,_ADResult ; get low byte MOVFF ADRESH,_ADResult+1 ; get high byte ENDASM LCDOUT F,Clr," AD 1 Vref = ",DEC ADResult'-------- ADCON0 = %00000001 ' A/D module enabled, channel 0 ADCON1 = %00001100 ' Vref = Vdd & 1V ref, AN0 = analog ADCON2 = %10101111 ' Right justified, 12 Tad, Frc clock INTCON = %01000000 ' Global ints disabled, enable peripheral interrupts PIE1.6=1 ' A/D interrupt enabled (for wake from sleep) ADCON0.1=1 ' Start the A/D conversion @ SLEEP ' Sleep until A/D conversion finished WHILE ADCON0.1 ' A/D complete? WEND ' PIR1.6=0 ' Clear A/D int flag ASM ; Put upper and lower byte of A/D in ADResult MOVFF ADRESL,_ADResult ; get low byte MOVFF ADRESH,_ADResult+1 ; get high byte ENDASM LCDOUT F,Ln2," AD 5 Vref = ",DEC ADResult'------- PAUSE 200 goto disp
