16F819 ADC problems
Results 1 to 13 of 13
    oups, sorry, since a long time i didn't use this built-in ADCIN statement. Still prefer to read/write register myself.
    BTW, what about now if you remove those PBP define and do something like
    ADCON0=%11000001
    ADCON1=%10001110
    Feb 2005
    Thanks both of you. After looking closer at the ADCON registers, which I had done a few dozen times, I noticed I only had seven not eight bits. Steve, thank you for your last post. When I pasted it to my program it was obvious I had left out one bit in each ADCON register. I did have to leave the DEFINE for number of bits and sample time to get it to work. The code is now working and returns 1024 for 5V.
    Mark
    DEFINE OSC 20
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    ADCON0 = %11000001
    ADCON1 = %10000100 ' AN4-AN0 D,A,D,A,A right justify
    TRISA.0 = 1
    TRISA.1 = 1
    adval1 var word
    adval2 var word
    clear
    High PORTB.5 ' turn on run LED
    low PORTB.4 ' low voltage LED
    loop:
    ADCIN 0, adval1 ' Read AN0
    adcin 1, adval2 ' Read AN1
    if adval1 < 512 then
    high PORTB.4
    low PORTB.4
    serout2 PORTB.3,16572,["ADVAL_1 = ",dec adval1," ADVAL_2 = ",dec adval2,13,10]
    goto loop
    MUC,
    Great to know it's working now.
    Have fun!
  1. Problems with ADC
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 29th January 2009, 18:34
  2. PIC18f2423 two 12bit adc input problems
    By Brandon in forum mel PIC BASIC Pro
    Last Post: - 16th December 2007, 10:47
  3. 16F819 ADC 8bit=127, Not 255?Help!
    By Accelerator in forum mel PIC BASIC Pro
    Last Post: - 24th June 2006, 18:34
  4. Need help with 16f819 10 bit ADC
    By bannrikae in forum mel PIC BASIC Pro
    Last Post: - 26th September 2005, 16:20
  5. Newby with ADC problems.
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 21:09
