16F819 ADC problems
Results 1 to 13 of 13
    Feb 2005
    Default 16F819 ADC problems
    I can not get the 10-bit A/D working correctly. The program below reads AN0 and turns an LED on if the voltage drops below half of VDD. At least that is what I want it to do. I am expecting to see a result of 1024 at 5 volts and 512 at 2.5 volts. The problem I am having is I don’t get 1024 or even close. If I DEFINE ADC_BITS 10 then the result is over 64000 at 5 volts. If I leave the DEFINE ADC out of the program I get 256 at 5 volts. I don’t know what is going on. Why don’t I get 1024 at 5V? I have been reading the data sheet for over an hour and have not been able to figure this out. The program is below.
    Mark
    DEFINE OSC 20
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    ' Define ADC_CLOCK 3 ' Set clock source (3=rc)
    ADCON0 = %1000101 '
    ADCON1 = %1000010 ' AN4-AN0 A,A,A,A,A right justify
    TRISA.0 = 1
    TRISA.1 = 1
    ' TRISB.4 = 0 ' Set PORTB.4 to output
    ' TRISB.5 = 0 ' Set PORTB.5 to output
    ' TRISB.3 = 0 ' Set PORTB.3 to output
    adval1 var word
    adval2 var word
    clear
    High PORTB.5 ' Turn on run LED
    low PORTB.4
    loop:
    ADCIN 0, adval1 ' Read AN0
    ' adcin 1, adval2 ' Read AN1
    if adval1 < 512 then
    high PORTB.4
    low PORTB.4
    serout2 PORTB.3,16572,["ADVAL_1 = ",dec adval1,13,10]
    goto loop
    For sure you don't read the good pin. Must use the pin name or alias.
    something like ADCIN PORTA.0, adval
    Feb 2005
    Hmm, the method I’m using to read the A/D is used on the melabs examples page. I have also used this method with a 16F688 without problems. I do get a varying number when I adjust a pot on the pin (0-256) for the 16F819. I need the 1024 resolution or I could use it as is. Something is setup wrong but I think I’m reading the A/D correctly. Correct me if I'm wrong. I will give your advice a try in a bit.
    Mark
    A melabs example;
    ' Read an analog voltage on RA0 and send the decimal representation
    ' of the value on the serial port at 2400 baud. 10-bit conversion
    ' yields 0-1023 result for 0-5 volt input.
    ' Define LOADER_USED to allow use of the boot loader.
    ' This will not affect normal program operation.
    Define LOADER_USED 1
    adval var word ' Create adval to store result
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10000010 ' Set PORTA analog and right justify result
    loop: ADCIN 0, adval ' Read channel 0 to adval
    Serout2 PORTC.6,396,["Value: ",DEC adval,13,10] ' Display value
    Pause 100 ' Wait .1 second
    Goto loop ' Do it forever
    Feb 2005
    Unfortunately your suggestion did not work. Here are some captured results. Starts with reading on ground, then roughly 2.5V then VDD (5V);
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 0
    ADVAL_1 = 30912
    ADVAL_1 = 31168
    ADVAL_1 = 31104
    ADVAL_1 = 31168
    ADVAL_1 = 31040
    ADVAL_1 = 31104
    ADVAL_1 = 31040
    ADVAL_1 = 31104
    ADVAL_1 = 31168
    ADVAL_1 = 31232
    ADVAL_1 = 31040
    ADVAL_1 = 31104
    ADVAL_1 = 31104
    ADVAL_1 = 31104
    ADVAL_1 = 31040
    ADVAL_1 = 31104
    ADVAL_1 = 31104
    ADVAL_1 = 31232
    ADVAL_1 = 31104
    ADVAL_1 = 31168
    ADVAL_1 = 65216
    ADVAL_1 = 65280
    ADVAL_1 = 65280
    ADVAL_1 = 65280
    ADVAL_1 = 65216
    ADVAL_1 = 65216
    ADVAL_1 = 65344
    ADVAL_1 = 65344
    ADVAL_1 = 65280
    ADVAL_1 = 65344
    ADVAL_1 = 65344
    ADVAL_1 = 65280
    ADVAL_1 = 65344
    Apr 2005
    Mark,
    I have the same problem using a 16f873. I know that this is not the right way, but it was a temporary thing that I did til I could research more, which I have not had time to do, but I think this may work for you:
    loop:
    LET adval1 = adval1/64
    'LET adval2 = adval2/64
    high PORTB.4
    low PORTB.4
    goto loop
    But there are pro's here that will show you the proper way
    Greg
    oups, sorry, since a long time i didn't use this built-in ADCIN statement. Still prefer to read/write register myself.
    BTW, what about now if you remove those PBP define and do something like
    ADCON0=%11000001
    ADCON1=%10001110
    Feb 2005
    Thanks both of you. After looking closer at the ADCON registers, which I had done a few dozen times, I noticed I only had seven not eight bits. Steve, thank you for your last post. When I pasted it to my program it was obvious I had left out one bit in each ADCON register. I did have to leave the DEFINE for number of bits and sample time to get it to work. The code is now working and returns 1024 for 5V.
    Mark
    DEFINE OSC 20
    ADCON0 = %11000001
    ADCON1 = %10000100 ' AN4-AN0 D,A,D,A,A right justify
    TRISA.0 = 1
    TRISA.1 = 1
    adval1 var word
    adval2 var word
    clear
    High PORTB.5 ' turn on run LED
    low PORTB.4 ' low voltage LED
    loop:
    high PORTB.4
    low PORTB.4
    serout2 PORTB.3,16572,["ADVAL_1 = ",dec adval1," ADVAL_2 = ",dec adval2,13,10]
    goto loop
    MUC,
    Great to know it's working now.
    Have fun!
    SWITZERLAND (french speaking)
    Default DEFINEs, what are they "doing" exactly?
    A few times ago, I had the same problem (16bits result instead of 10bits) as long I didn't notice my result was not RIGHT justified.
    In fact, I wrongly assumed that the "DEFINE ADC_BITS 10" would handle this... but it doesn't.
    Where can one see what exactly each PBP DEFINE statement does? Couldn't find this in the manual.
    Roger
    You can see the RESULTS of a DEFINE in the .lst files, or you can manually scan thru the .lib's and find whichever particular DEFINE you need to find. It's a bit of a pain...
    Feb 2005
    Kolkata-India
    Default Discard my post
    Sorry if Vbulletin has already sent notification emails. No intentions biting some bytes on the server.
    Sougata
    Quote Originally Posted by sougata View Post
    I never used the PBP ADC routines and used my own always but never got 1024 only 1023 ?
    Well, that was almost 2 years ago. Maybe things worked differently back then
    Feb 2005
    Kolkata-India
    Default Skimask you are overclocked or may be I should SLEEP now
    Skimask how can you be so fast replying.... I am always beaten out
    Sougata
  1. Problems with ADC
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 29th January 2009, 17:34
  2. PIC18f2423 two 12bit adc input problems
    By Brandon in forum mel PIC BASIC Pro
    Last Post: - 16th December 2007, 09:47
  3. 16F819 ADC 8bit=127, Not 255?Help!
    By Accelerator in forum mel PIC BASIC Pro
    Last Post: - 24th June 2006, 17:34
  4. Need help with 16f819 10 bit ADC
    By bannrikae in forum mel PIC BASIC Pro
    Last Post: - 26th September 2005, 15:20
  5. Newby with ADC problems.
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 20:09
