Using SSPWM on more than one Output (Runtime outputpin Changement?)
Results 1 to 4 of 4
    Oct 2011
    Default Using SSPWM on more than one Output (Runtime outputpin Changement?)
    Hi guys,
    I need to use SSPWM for 3 output but not at the same time.
    I need also 2khz so i can't use SSPWM multiple (limit of 1000 hz on 48Mhz clock)
    Any help/suggestion on this would be appreciated. :-)
    Oct 2011
    Default Re: Using SSPWM on more than one Output (Runtime outputpin Changement?)
    The SSPWM library is at
    http://www.pbpgroup.com/modules/wfse...hp?articleid=6
    It works very well, but only with one pin ?
    Any idea ???
    Are the three outputs the same duty and freq or do they need to vary independently duty / freq or both?
    I use 10-90% duty sspwm at 2khz on an 8mhz pic put only on one output it works very well.
    If you only need one output active at any one time you could just direct the sspwm to the reqd pin at the reqd time.
    If you need two or more working then you might be stuck.
    Oct 2011
    The freq is 2 khz for all (and only one output ), so i can redirect Sspwm?
    Many tanks, i'll check it as soon as possibile.
