Problem proramming PIC 16F886 with PICKIT2?
Results 1 to 15 of 15
Threaded View
  1. #14
    Nov 2008
    Default Re: Problem proramming PIC 16F886 with PICKIT2?
    Give it a go with PGM pulled down. I only found this after intermittent programming problems on a project some time ago, now allways keep this pin in a way it can be pulled down (even if it means an extra pad on the PCB).
    If the device is new then LVP is enabled - note 5 on P228, but i also suspect if the device is erased is default's back to this.
    Edit:
    In your case pullde to VCC via 10K, just shorting RB3 to GND while programming would do the trick.
