Serialin timeout
Results 1 to 6 of 6
    Nick's Avatar
    Nick Guest
    Default Serialin timeout
    Hi Team,
    I’m using PBP 2.45a and I’m trying to get a PIC 16F628
    to do some LED blinking and then go in stand by until it
    receives an “OK” on the serial in or a large timeout goes by.
    I’m using variable index to control this timeout.
    This is how I thought of doing it but it does not seem to work (at list the
    timeout part). After the initial shot on power ON it just hangs up and does nothing.
    INCLUDE "bs2defs.bas"
    @ device pic16F628, intrc_osc, wdt_on, pwrt_on,mclr_off,protect_off
    red VAR PORTB.4
    green VAR PORTB.5
    serial_in VAR PORTB.0
    password VAR BYTE
    index VAR BYTE
    cmcon=7
    TRISB=%10000001
    Pause 1000
    loop:
    index=0
    High red
    Pause 500
    High green
    Pause 500
    Low red
    Pause 500
    Low green
    main_loop:
    index=index+1
    SerIn serial_in,T2400,100,again,["O"],password
    IF password="K" Then
    GoTo loop
    Else
    again:
    IF index>99 Then
    GoTo loop
    Else
    GoTo main_loop
    EndIF
    EndIF
    Any ideas what I’m doing wrong?
    Thank you for your attention.
    Feb 2004
    Germany
    Nick,
    since you haven't told us which device is sending the "OK"
    and I don't know what your schematic looks like,
    all I can do is guessing.
    It Looks like your SERIN never times out.
    are you sure T2400 is the correct mode?
    Try N2400.
    Search the board for SERIN or SERIN2 you'll find many examples.
    regards
    Ralph
    Nick's Avatar
    Nick Guest
    Hi Ralph,
    Thank you for your input
    I'm using an other PIC to send the "OK" with the Serout T2400 mode.
    This part works.
    I'm having problems with the SerIn timeout only.
    I will also try the search.
    Also look to your config fuse... there's a error. You should use MCLRE_OFF instead or tie your MCLR pin to VDD
    Nick's Avatar
    Nick Guest
    Thanks Team.
    I made the suggested changes and some resoldering and it all works now.
    Thank you again.
    You're welcome.
  1. Serin2 Timeout
    By tazntex in forum Serial
    Last Post: - 15th August 2008, 16:40
  2. SERIN Timeout
    By George in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2007, 16:06
  3. Need help with timeout
    Last Post: - 10th June 2006, 16:38
  4. 16F628A Serin timeout and Timer1
    Last Post: - 27th March 2006, 00:20
  5. SERIN & Timeout
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 08:33
