First try at DT_INT's, I failed! help please!
Results 1 to 6 of 6
    Default Re: First try at DT_INT's, I failed! help please!
    I’m using X1 board with 16F877A and pulsing RB0 with a wire lead.
    That's the problem.
    If you are using a wire to +5V, there's nothing to pull it back down.
    The pin will hold a charge, and will slowly drain off, allowing it to re-trigger after a few seconds.
    If you add a pull-down resistor it should work better.
    Or, you can turn on PORTB pull-ups (OPTION_REG.7 = 0), make PORTB.4 LOW so you can use SW1 pushbutton.
    Changing to OPTION_REG.6 = 0 will make it trigger on the falling edge (button press) instead of the rising edge (button release).
    Alabama,USA
    Thanks Darrel, I'll give it a try!
    Alabama,USA
    Yep! works great!
    This is funny, I did this very exercise yesterday and posted it in the Code Examples. LOL
