Potentiometer reading
Results 1 to 13 of 13
    Oct 2011
    Default Re: Potentiometer reading
    Hi again
    Read 'Selecting the A/D conversion clock' in the datasheet
    It says R/C clock source not recommended at frequencies above 1mHz
    For 20mHz clock source should be %010 or %110 (2 decimal or 6 decimal) ie
    Define ADC_CLOCK 2
    or
    Define ADC_CLOCK 6
    Phil
    Jun 2011
    Philippines
    Hi jetpr and Sherbrook, I tried your suggestions but did not work for me...I will try to get another pot today and try it again...thanks for sharing your ideas.
    tacbanon
    Jun 2011
    Philippines
    Default Potentiometer reading(solved)
    Hi everyone, I got the code to work but on 10K pot... Thanks for the inputs everyone.
    I used the same connections and the codes from forum's input.
    DEFINE    OSC 20
    ' Define ADCIN parameters
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    adval Var Byte          ' Create adval to store result(slider)
    TRISA = %11111111
    ADCON1 = %00000100
    mainloop:
       ADCIN 0, adval       ' Read channel 0 to adval
       Serout2 PORTD.2, 84, [$1B,$45]      ' Clear
       Serout2 PORTD.2, 84, [" Slider: ",#adval]'
       Pause 150            ' Wait .15 second
       Goto mainloop        ' Do it forever
    regards,
    tacbanon
