I'm looking for a code efficient method to build a small table during runtime.
Although I’ve looked at mel PIC BASIC Pro, FAQ, Code Examples and PBP Extensions I haven’t found an answer; albeit, I may have overlooked an answer.
Here is the code example I’ve started even though it doesn’t compile.
highpres1 var byte
highpres2 var byte
highpres3 var byte
highpresn var byte
if pres > 1700 then ‘voltage from pressure transducer
high hiled ‘led on to verify that pressure > 1700
for i = 1 to n step 1
adcin 4, highpresi ‘the ‘i’ at the end of highpres (i) is intended to
‘identify ‘successive variables
next i
Question: How can ‘i’ be used to identify successive variables without extensive code?
Bob
